Hiking boots for wide feet |
Pewit ![]() Groupie ![]() ![]() Joined: 25 Jan 14 Location: Sydney, Australia Online Status: Offline Posts: 72 |
![]() ![]() ![]() ![]() Posted: 02 Mar 17 at 7:29am |
I sail a Weta (OK it's a multihull but it sails like a skiff with stabilisers) and due to the amount of spray across the tramps and wind chill, I prefer to wear hiking boots unless the water is really warm or the wind very light.
My feet are wide (EE) and I have large veins on the surface of my instep which get restricted against the tendons if the boot is too tight causing cramps (I've had similar problems with ski and skating boots). ![]() I've been using Gul CZ Windward boots for the past year and while they are comfortable, they're not very durable so I need to replace them - any suggestions for alternatives I should look at? |
I have wide feet and use the Gul All Purpose boot. Might not be the same issues as you have, though. Sounds like you need a trip somewhere to try them all on. Dinghy show a bit far from Sydney, though!
Why not wear your well fitting summer shoes of choice over neoprene socks. Rooster in the UK do a range of very effective products.
I am also often disappointed by the poor durability and short life of regular dinghy boots. I have seen heavier boots advertised for canoeists but not handled in the flesh.
I have a pair of these. They're a bit heavy but built like a concrete dunny and, while I went a size big to fit over my drysuit they seem to have plenty room in them. As Rupert says try before you buy if at all possible (or buy mail order so you can send them back, a bit of hassle but they need to be right).
You must be hard on them. I have had a pair for 4 seasons and have found no problem with durability: i usually sail once a week for 10 months of the year. I have tried various other boots including those mentioned above and have found nothing else as comfortable for my wide feet.
My crew went out and bought a pair after trying mine on once as he also has the wide foot problem. |
Merlin Rocket 3609
Ronstan boots are good for wide feet imho....
Where is the resident forum Hobbit when you need him?
Anyone seen Grumpf today?
Sorry late in today, I've been out stocking up on firebricks due to the unprecedented demand from woodbotherers threatening to 'See me at the show'. So I also have quite wide feet, sized 9.5 (10.5 US) and wherever possible (when I'm not due to stand around freezing my butt in mud and goose droppings), I retain my split toe Oneils. If on the other hand I have to wear the death bag of torment, I bought a set of Clarkes, yes Clarkes, they did some sailing trainers for a limited period, probably due to the usual spring in uptake from the moribund ones. Now I did notice the other day that girly brand Jil or Gil I think it was were offering some new delights for your feet, might be worth a google. They might also be more resilient to all the rocks in the water under this bridge I'm currently trolling from. Late edit.. here they have laces so no need to be too tight. Here Edited by iGRF - 02 Mar 17 at 11:26am |
fleaberto ![]() Far too distracted from work ![]() Joined: 12 Jan 09 Location: United Kingdom Online Status: Offline Posts: 302 |
I have a pair of Magic Marine Regatta boots that are pretty wide and generally roomy.
They've seen me through 4 seasons so far, including 3 trips to Nielson when I'm doing 30+ hours a week of sailing. No durability issues with these from me. |
My hiking boots suit my wide feet, they are just like hiking boots for narrow feet, but they have two splits in them where my toes stick out the side and get chilly in January.
Rooster are good if you want all your toes inside though IMO ! |
