Spinnaker coatings |
| Author | ||
gbrspratt
Joined: 26 Sep 11 Location: Felixstowe Online Status: Offline Posts: 170 |
Topic: Spinnaker coatingsPosted: 24 Feb 16 at 10:44am |
I've heard that in some classes (one design?) Spinnaker coatings could be illegal? As it's not stated in the rules it can't be done? Taking a sail out of one design? I guess this goes for all sails, not just kites.
jeffers
Posted: 24 Feb 16 at 10:54am |
If written in to the class rules that coating 'x' may not be applied then sure it is possible.
It becomes a 'measurement' issue IMO as the sails must have been measured and approved. I am guessing part of the measurement process would be a declaration that coating 'x' has not been applied.
gbrspratt
Posted: 24 Feb 16 at 11:00am |
So if a laser had its main coated, would that still be class legal?
jeffers
Posted: 24 Feb 16 at 11:13am |
No because the Laser has the Fundamental Rule that covers this:
PhilHigh
Joined: 17 Jan 09 Location: United Kingdom Online Status: Offline Posts: 8 |
Posted: 24 Feb 16 at 3:51pm |
You could probably class spinnaker coating as coming under maintenance. A quick look at the laser rules suggests coating the main could be fine.
Rule 26 a: Repairs and preventative maintenance to the sail, hull, deck, centreboard, rudder, mast, boom or any fittings and fixings may be carried out without violation of these Rules provided such repairs are made in such a way that the essential shape, characteristics or function of the original are not affected Rule 26 f: The use of lubricants is unrestricted except that they shall not be used on the hull (below the gunwales)
jeffers
Posted: 24 Feb 16 at 4:04pm |
You would fall over on this though:
As the coating may alter the characteristics over what it would have been originally.
Edited by jeffers - 24 Feb 16 at 4:05pm |
Rupert
Posted: 24 Feb 16 at 5:50pm |
More likely the coating will bring a sail back to nearer what the original characteristics were.
Guests
Posted: 24 Feb 16 at 11:16pm |
It's your boat, you paid for it, and if you want to coat your sails with something just go for it. If you want to give your kite a bit more life, it's your kite.
Posted: 25 Feb 16 at 9:59am |
But if you race with other people under the RRS then breaking class rules is cheating, which sounds as if its what the OP is trying to avoid. If all you do is cruise round the bay do what you like. |
andymck
Joined: 15 Dec 06 Location: Stamford Online Status: Offline Posts: 397 |
Posted: 25 Feb 16 at 10:38am |
Spinnakers come coated. So having had a discussion with my sailmaker there is no point in getting a new fast spinnaker done. What the coatings do is prolong the life of those top of the fleet cast offs and training spinnakers to make them easier to use.
I quite openly get mine done. Not my open meeting kites as they are new. But as soon as they need replacing, and it prolongs their useful life. No one has ever complained or protested. Only asked who I get to do it do they can send theirs too. Seeing a kite that the week before was a wet rag slide effortlessly from the sock and shed water is all you need to see to be convinced. It is also not very expensive. Anything that prolongs the length of usefulness has to be good. Andy McKee Ps I send mine to Scam at Suffolk sails. rejuvenated Musto Kite still good after 2 seasons use. Much better than do it yourself waterproofing. |
Andy Mck
