New Posts New Posts RSS Feed: Leaving a laser outside over the winter
getafix View Drop Down
Post Options Post Options   Quote getafix Quote  Post ReplyReply Direct Link To This Post Topic: Leaving a laser outside over the winter
    Posted: 06 Dec 13 at 9:48am
bubble wrap (the stuff with the big bubbles) under the cover will stop freezing water and freezing cover sticking to your decks and enable better air-flow, started doing this with wooden-decked boats but found it very useful with Lasers and other GRP/FRP boats too
RichTea View Drop Down
Post Options Post Options   Quote RichTea Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 13 at 9:03pm
Googled jug mop, what's wrong with a sponge... Anyway here is it
RS200
jeffers View Drop Down
Post Options Post Options   Quote jeffers Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 13 at 9:06am
Originally posted by deadrock
Keep your mast hole ice-free without having to turn the hull upside-down:
1: Take a wire coat-hanger, pull the bottom stringer away from the hook so you have a long prodder with a hook on the end.
2: Attach a piece of absorbent capillary sponge to the hook, and tighten the hook around it.
3. Keep it in your boat-space, and after each sail, poke it down the mast hole to get rid of the water.
Great idea above. Or go to your local Dunelm (or similar) and buy a jug mop for about 70p. Mine lives in the front pocket of my foil bag and I always empty the tube.
deadrock View Drop Down
Post Options Post Options   Quote deadrock Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 13 at 8:22am
If ice forms at the bottom, the mast doesn't go all the way down, and may be above the rim of the metal cup which sits at the bottom of the mast-hole. The mast-tube is only a thin tube of GRP, and if the base of the mast is above the rim, the mast will go through this tube very easily, requiring an expensive repair.
Late starter View Drop Down
Post Options Post Options   Quote Late starter Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 13 at 9:57pm
My Lasers used to spend all year at the club and never seemed to come to any harm. Other than what others have already said (ie ensuring the boat is well tied down, and can drain) I always made sure the boat had a decent cover. And that was it, they are tough old boats.
Post Options Post Options   Quote RichTea Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 13 at 8:11pm
Don't park it under a tree, you'll regret it!
I would empty the mast foot as has been mentioned, ensure the bailer is open, leave on tyres to keep nose up to drain water out and spread the mast outdo no water pockets can form. Make sure it is tied down well even at home.
RS200
Post Options Post Options   Quote jeffers Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 13 at 3:29pm
My Lasers have always live outside. Just make sure the mast step stays empty and that any large build up of snow is removed quickly and it should be fine.
Mine have never suffered any damage that I can see from being left outside.
transient View Drop Down
Post Options Post Options   Quote transient Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 13 at 1:33pm
If the mast step fills with water and freezes/thaws then I suppose it possibly might cause some damage.....turn it upside down and put a tarp over it.
Edited by transient - 04 Nov 13 at 1:41pm
PeterG View Drop Down
Post Options Post Options   Quote PeterG Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 13 at 1:18pm
Mine, of a similar number, has always been left outside over the winter (until this year). It's never suffered in any way I can detect - even when my idiot son left the self bailer up after he'd sailed it last sail of it's season and it spend a good part of the winter with a block of ice sitting at the bottom of the cockpit.
Peter
Ex Cont 707
Ex Laser 189635
DY 59
headtowind View Drop Down
Post Options Post Options   Quote headtowind Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 13 at 1:06pm
Question -
I have a laser in good nick and not to old - 189k. I have always managed to keep it inside over the winter but for various reasons will struggle for space this year. How much detriment will there be leaving it out over the winter working on the assumption there will be some lengthy cold snaps?
Thanks
