New Posts New Posts RSS Feed: laser top mast
laser top mast
ian.r.mcdonald View Drop Down
Post Options Post Options   Quote ian.r.mcdonald Quote  Post ReplyReply Direct Link To This Post Topic: laser top mast
    Posted: 13 Aug 13 at 2:16pm
have ordered the rivets today. was about to order an new sail and after so long out of the boat had forgotten the effect of a mast breaking on the sail itself
THANKS GUYS!
jeffers View Drop Down
Post Options Post Options   Quote jeffers Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 13 at 9:26am
The above is good advice. I end for ended my old top section and it was as good as new and still going strong.
deadrock View Drop Down
Post Options Post Options   Quote deadrock Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 13 at 8:15am
Two rivets, probably quite an old top-section. There's a point of view that if it's lasted this long it's going to last some time more, but as you don't know its history I'd be wary of using it with a new-ish sail. The most likely time you'll know it's near to breaking is just after it snaps.
With two opposing rivets it's probably best to end-for-end it. Common sense (and the ILCA Rules) require you to seal each of the old holes (now at the top of the mast) with a rivet, to keep the top-section relatively watertight. Just taping over the holes doesn't satisfy the ILCA Rules. However, an end-for-ended top-section is still likely to take in water during a total inversion, because the inverted top of the mast is under an additional pressure of about 8 p.s.i. Taping over the riveted hole is a useful preventative.
Edited by deadrock - 13 Aug 13 at 5:16pm
Post Options Post Options   Quote ian.r.mcdonald Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 13 at 10:47am
I have an old laser- the top mast is (I assume) the original in good condition. It has two rivets on the collar which I assume is the original design.
should I "end to end" it to allow me just to use one aft rivet?- or am I ok just to leave alone?
