New Posts New Posts RSS Feed: Cutting Acrylic Transom Flaps
rb_stretch View Drop Down
Post Options Post Options   Quote rb_stretch Quote  Post ReplyReply Direct Link To This Post Topic: Cutting Acrylic Transom Flaps
    Posted: 29 Jan 13 at 10:15pm
Did some gelcoating today as discussed in other thread. Whilst doing it I snapped my transom flaps which were made out of clear acrylic, about 2 mm thick.
Went to Wickes today to buy a sheet and have just spent the last 2 hours trying to cut the flaps out but failing. Using just a stanley knife was impossible (it's got curves), jigsaw split it, saw was the same. I had most luck heating a knife up repeatedly with a blow torch, but split them when trying to take out of the sheet.
So how do people cut their transom flaps?
sargesail View Drop Down
Post Options Post Options   Quote sargesail Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 13 at 10:26pm
Buy the material from P&B or similar and it's cutable.  I used both scissors and a scalpel.
Post Options Post Options   Quote iGRF Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 13 at 11:17pm
Hot Wire?
transient View Drop Down
Post Options Post Options   Quote transient Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 13 at 1:10am
Never had a boat with flaps but.....I,d use polycarbonate and cut with a fret saw. Polycarb will last much longer. The local sign writers/engravers should have some.
MattTrinder View Drop Down
Post Options Post Options   Quote MattTrinder Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 13 at 7:29am
I bought polycarbonate sheet off eBay.
Oatsandbeans View Drop Down
Post Options Post Options   Quote Oatsandbeans Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 13 at 7:34am
The best would be a band saw with a narrow blade so that it can do the curves. If none of your mates has one I think that it would be possible with a good jigsaw. With the right blade, not too agressive -many small teeth, and get the speed right up before you start the cut then it wont have a chance to shake the sheet about and ruin it, once it is cutting properly it should then be OK.
MerlinMags View Drop Down
Admin Group
Admin Group
Post Options Post Options   Quote MerlinMags Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 13 at 9:05am
If you have to use a saw, perhaps sandwich the plastic between two layers of scrap wood, to keep it from flapping.
Or get those scissors which can cut through 2p coins (if I remember the advert rightly?).
RichTea View Drop Down
Post Options Post Options   Quote RichTea Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 13 at 10:17am
Tape it with masking tape first between the two cuts, ie down the join.
laser193713 View Drop Down
Post Options Post Options   Quote laser193713 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 13 at 10:30am
Ah the joys of having access to a CNC machine!
Jack Sparrow View Drop Down
Post Options Post Options   Quote Jack Sparrow Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 13 at 11:46am
fret saw or tile saw and then sand down edges
