New Posts New Posts RSS Feed: RS200 or ...?
RS200 or ...?
 Post Reply Post Reply Page  <1 3456>
sargesail View Drop Down
Post Options Post Options   Quote sargesail Quote  Post ReplyReply Direct Link To This Post Topic: RS200 or ...?
    Posted: 24 Sep 12 at 11:58pm
GRF is overdue his medication it being 1130....he managed two paragraphs of sense and then the voices spoke....
ben_a View Drop Down
Post Options Post Options   Quote ben_a Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 12 at 7:29am
Originally posted by G.R.F.
Don't do it, go with the 200, the first thought is always the best, you've stumbled into a world of crazed old dodderers determined to cling on to yesterday.
The chances of you getting one of those N12 things that is remotely on the pace with all the others is between slim and none, with the 200 you get what everyone else gets, it's a neat little boat with lots of fellows sailors and a good social scene. It performs really well across a wide range, doesn't stick in a drifter has plenty of volume so is equally OK on fresh or salt water and is relatively maintenance free, but, if you have issues is backed by great spares and service online if necessary.
As to the ludicrous suggestion that using a clumsy antediluvian old school spinnaker and pole requires anything more than charisma removal at best or a frontal lobotomy at worse, that comes from someone who has no idea of downwind assym tactics, something that is fun to learn, and the 200 can go pretty deep in any event.
Hahaha - you summed me up with your first paragraph!
You have inspired me to have one more go in a 200 (had very light airs last time) but my observations are pretty much as follows:
1) The 200 is a bath tub - I much preferred the finer balance of the 12
2) The 200 kite is so small that the assym tactics (which I am a fan of) are not used except in a blow
3) I can get competition at a club level in any boat. I don't feel the need to 'win' - my experience from racing is that you get your kicks from your battles on the water which could be with excellent sailers in slower boats or terrible sailors in fast boats. I enjoy the position over the line and I'm less bothered by what happens after the PY adjustment lottery.
4) The dangly pole on the 200 is brilliant.  I never expected it to be so fun / useful.  All boats should have one.
Bottom line, if the National 12 had a decent assy then I think it would be my perfect boat, but although the RS200 looks like it would fit on paper, in practice it does not deliver because of the bathtub feel and tiny kite.
The 12 is not perfect.  I am not a fan of the rear sheeting (but I can change this) and to be honest there are more rig controls than I will ever really use with any confidence, but the feel of the boat is what is driving me down that route...
I'll give the 200 another chance in more wind and see if that changes my opinion - the club racing and strong circuit are definitely plus points.
SoggyBadger View Drop Down
Post Options Post Options   Quote SoggyBadger Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 12 at 8:22am
Ben,
Go with the N12. You'll end up a far better sailor and if you do travel to any opens you'll meet up with a vastly more knowledgeable crowd.
SB
ifoxwell View Drop Down
Post Options Post Options   Quote ifoxwell Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 12 at 9:08am
I dont get it Graham.... Ok the boats have developed in a distorted way following the rule set that is in place, but they have developed, and into fantastic sailing machines that for a small boat with small sails are about as quick as you can go!
A modern carbon 12 is a huge step up from the old wooden boats you may have seen and when you add a T foil into the mix are a fantastic modern take on a dinghy.
And for me one of the great strength of the design, unlike others that you have mentioned, is that they are so well refined they go well in any conditions. Everyone will tell you how good they are in a drifter but the best fun is to be had in a F5 + when they really fly, and they sail well in everything in between
If there is a fleet of RS200s to race against then the 200 wins but in all other respects the 12 is a far more rewarding boat to sail.... and more modern!
Ian
RS300
pondmonkey View Drop Down
Post Options Post Options   Quote pondmonkey Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 12 at 9:23am
well of course the benefit of a 12 is that you can change all of that if you want a simpler set up, but the chances are you won't.  You'll be left with lots of controls, lost with your head in the boat tweaking this or that in a hope you can catch up with those around you.  You can read books, ask advice and even copy other folks settings- but all this is only scratching the surface of the problem, as each twelve and each rig is different, only you can really learn how to make it perform with lots of time on the water.  Even if the previous owner was a total boat geek and gives you a manual of settings, they might not be appropriate to your build, your sailing style or your prevailing waters and winds.... so it's a long, long road of discovery that will probably offset frustration with eureka moments.  This will either appeal, or it will not, but be under no illusion about the commitment you are about to make when buying a boat like a N12.
There will be times when you make changes and think you've made improvements to the boat but in truth you've just ballsed-it up pimping in the wrong direction.  There could be times when you've made changes that make a massive difference- especially if you find someone knowledgeable and empathetic with you and your sailing to give you salient advice.  All of this can be highly rewarding- especially for the technically minded.  That extra knot of VMG boat speed not just coming from choosing  the right shifts and clean air, but from the change over of a different cut mainsail to match your new mast and weight- that was well worth the £800 you just spent on it if you actually value this aspect of dinghy sailing.
Alternatively you could buy an RS200, jump in it and go sailing, pretty much safe in the knowledge that if your boat follows a basic recommended set up, it will be as competitive as any other you're racing- given of course the normal easily-understood variables such as sail age, a straight mast and foils free from shark bites, all of which could be replaced within 2 days using an internet order direct to work or home.
There's no shame in wanting easy sailing, especially if you want lower levels of shorter term depreciation... I know what I'd rather do in my free time.
Edited by pondmonkey - 25 Sep 12 at 9:34am
Post Options Post Options   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 12 at 9:30am
Ben, for what it is worth I think there were 3 200's and 2 N12's sailing at Chew on Sunday, so you'll have others to race whatever you choose.
Post Options Post Options   Quote ben_a Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 12 at 10:04am
Pondmonkey - You make a lot of sense, and the hard truth is that I will never have the time or commitment to tune the rig to perfection on a 12.  However, at the end of the day it is not just the tuning that requires dedication and time on the water; it will take just as much commitment to learn how to sail a boat well in order to keep up with those at the front of the fleet.  The RS sailors at Chew looked pretty handy and I doubt that I'll arrive after a 10 year break and find myself at the front of the fleet.
I figure I will have to put in my time on the water whichever way I go.  The question then becomes which boat provides the most inspiration and fun while hanging out at the back.  That all said I will give the 200 another chance.
Peaky - Yes - I was in one of the 12's.  I get the impression that there are generally a few more 200's about at Chew but that there would be competition either way.
Post Options Post Options   Quote pondmonkey Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 12 at 10:13am
I can't fault that... but from personal experience I would rather be honest with myself and accept I got spat out the back because I didn't sail well, than blame myself for not setting it up right, or buying the right component or having the wrong handicap allocated to me.
I would also say after a 10 year hiatus, I'd recommend reducing the variables as much as possible (if you were looking for a singlehander, I'd recommend a Laser for a season or two)  The N12 class isn't going anywhere but forwards, so it could always be something to move into in the future.
Either way both boats seem viable options for you as you've got people to sail against.  You've got a nice dilemma to have... enjoy whichever way it goes.  Thumbs Up
Edited by pondmonkey - 25 Sep 12 at 10:17am
Post Options Post Options   Quote ben_a Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 12 at 10:21am
[QUOTE=ben_a]I would also say after a 10 year hiatus, I'd recommend reducing the variables as much as possible
I think that this is the strongest argument for a 200 and is what makes it the 'sensible' choice.
Post Options Post Options   Quote pondmonkey Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 12 at 10:38am
Yep- you could get one (nice-ish secondhand would be the best for the money/depreciation), sail it for a couple of years and learn absolutely loads, with class training days aimed specifically at new entrants to the class etc.  The social vibe's excellent too, but I guess that's true of the 12s as well.  You'd also learn from others sailing them in the club too, simply by racing and chatting when you get the opportunity- it's an easier approach than bimbling and measuring rakes and rig tensions for sure.
As for the boat itself, I'm just jealous/biased... one of my favourite boats I ever owned was my RS200, the small kite is actually a marvellous feature that you can only truly appreciate once you're racing it over a few weekends and you see how you can use it when other asymmetrics are plodding around the cans under white sails.  We had ours for about 6 months in total as my wife hated dinghy sailing.  I'd love to be sailing one again, especially as when we had ours there were a proper fleet of them at my club, probably with the best sailors from the club racing them with family.  Who knows... two little 'uns in the pipeline these days so maybe one of them will step up for crewing gig in the future.  I know everyone says they're tippy, but they'd still be my first choice if there was a fleet and I had a suitable crew.
