New Posts New Posts RSS Feed: Which skiff to choose
 Post Reply Post Reply Page  <1 345
49erGBR735HSC View Drop Down
Post Options Post Options   Quote 49erGBR735HSC Quote  Post ReplyReply Direct Link To This Post Topic: Which skiff to choose
    Posted: 03 Oct 06 at 11:13pm
The 5k kite is fractional but only a little bit bigger than the B14. Reckon the power to weight ratio of the B14 is larger but the 5000 does carry a fair bit of momentum when the wind is less stable.
Dennis Watson 49er GBR735
Helensburgh S.C
boatshed View Drop Down
Post Options Post Options   Quote boatshed Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 06 at 8:08am
Originally posted by jbungener
I am looking for a skiff to go sailing with my wife. I have done my share of swimming but she is still learning the ropes. We weigh in at a combined 160Kg (350lbs)
An Rs800, Boss or 49er are probably too much.
a 29er is too small.
Maybe the ISO.
I was thinking of the laser 5000. It seems in decline, why is that?
I am looking for something that will forgive our early mistakes and yet progress with us. IS that possible?
Which boats would you recommend?
Thanks
If an RS800 is too much, then a B14 will also be too much.  Don't be fooled by the fact they are sitting out boats.  They are great value and quality of the circuit is right up there but I reckon if you are not pretty good in, say a Lark, National 12, RS 400 etc, then you will become disillusioned with racing a  B14.  The learning curve to get you somewhere near competitive is very steep.  If you crack it, then the, non-marketed & commercially ignored B14 is hugely rewarding. It may even be one of the best boats you'll ever sail.
Steve
combat wombat View Drop Down
Post Options Post Options   Quote combat wombat Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 06 at 12:42pm
True that the 5k has momentum!  Great boats, would be so much better if they weren't so heavy.
Boatshed, you're probably right about the B14 being not easy, you have to be competent in a 400 certainly to get them up to speed.  They are forgiving though, and not nearly as tippy as other boats of a similar speed.
You do have to be pretty agile, the wierd thing about sailing the B14 is that you have to go from sitting down to standing up a lot, unlike a trapeze boat where you come off the wire standing up, run across the boat and hook on - the B14 requires you to hike, then get back in, stand up, run about 10 feet then hook your feet under the straps and hike... the technique is difficult to master!
As for the class, yep the competition is fierce and there are 5 boats that always take the top places (and have done for years!).  Even at the Worlds they didn't let the Aussies in the top 5.  But, its good to learn from them and maybe in 10 years...
B14 GBR 772
Suede View Drop Down
Post Options Post Options   Quote Suede Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 06 at 8:01pm
What is the best crew weight for the 800? Me and my crew a combined weight of 170-180kg. I guess we are a bit too heavy...but we do not aim to race since there are no 800s in Sweden... How much would it affect boatspeed?
May the Force 5 be with you
