New Posts New Posts RSS Feed: What gives a boat 'height'?
 Post Reply Post Reply Page  <1 234
Guest View Drop Down
Post Options Post Options   Quote Guest Quote  Post ReplyReply Direct Link To This Post Topic: What gives a boat 'height'?
    Posted: 09 Jun 09 at 11:48am
The angle of the burgee when sailing upwind will vary depending on how windy it is ... the more wind there is the more it will run down the centreline.
I would never look at a burgee upwind unless I am bobbing around on a gravel pit in no wind trying to work out what is going on ...
Jack Sparrow View Drop Down
Post Options Post Options   Quote Jack Sparrow Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 09 at 11:35am
Sounds to me like you have been sailing in conditions with a bit of wind shear. And you need to sail with a little more twist. Let the kicker off and the top have of the sail won't stall so much. Is the main top leach tell tail streaming?
ellistine View Drop Down
Post Options Post Options   Quote ellistine Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 09 at 11:20am
We seem to be struggling for height when sailing upwind in
our Vago. I appreciate that a Vago isn't going to be
setting the world a light in it's upwind abilities but I'm
sure we used to be able to go higher than we are at the
moment. I'm steering to the telltales yet the burgee
doesn't seem to point as far forward as it used to.
What are the key attributes of a boat that allows it to
sail higher into the wind?
