New Posts New Posts RSS Feed: hiking...
hiking...
 Post Reply Post Reply Page  <1 234
jpbuzz591 View Drop Down
Post Options Post Options   Quote jpbuzz591 Quote  Post ReplyReply Direct Link To This Post Topic: hiking...
    Posted: 04 Sep 06 at 7:51pm
Originally posted by NickA
Trapezing at least wrecks a different bit of your knees and back .... but you won't notice 'till you hit 40!
I have at 17, but been doing a load of cycling on the way to work over summer which has helped, so am now ready to get back into a boat rather than sitting in a rib teaching people.
Jp Indoe
Contender 518
Buzz591
Chew Valley Sailing club
Bristol
NickA View Drop Down
Post Options Post Options   Quote NickA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 06 at 7:41pm
Maybe an RS600 with the wide racks and short rig?
blaze720 View Drop Down
Post Options Post Options   Quote blaze720 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 06 at 6:02pm
Try a Blaze - turbo charged armchair racing and really kind on 'laser' knees once you get moving !  You might be a bit light for it though ....Wings and good hikers are surprisingly comfortable and I'd recommend pasta and good bitter to pile on a few KG's.  Many years ago I had a great  OK whch was exceptionally comfortable as well, only really beaten by the Tasar for comfort if you go for a crew boat (min crew weight is 130kg so you could find a 'medium' partner.
Blaze 720
mike ellis View Drop Down
Post Options Post Options   Quote mike ellis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 06 at 5:14pm
i dont get any problems in the feva but then you dont want a plastic boat, unless you want to buy mine . i found the 200 ok to hike from.
Also International 14, 1318
Jon Emmett View Drop Down
Post Options Post Options   Quote Jon Emmett Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 06 at 3:14pm
It is your technique not the boat which is causing issues with your joints. I am sure Y&Y will have an article out in the not too distant future...
Prince Buster View Drop Down
Post Options Post Options   Quote Prince Buster Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 06 at 10:02am
Yeah I've tried quiten a few different laser hiking techniques but none have really worked.  The problem I face is that I'm too light for most boats and would ideally want to helm from the wire.  But until I can find a boat where a 55kg kid can do that I'm in a bit of a no-win situation
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 06 at 9:05am
Anything with a sensible amount of freeboard - say double or more what the Laser has will be much better. But the ultimate boat for sitting out without boiling your kness is the International Canoe.
There may well be technique things you can do to make the LAser a bit easier on your knees though.
Edited by JimC
Guest View Drop Down
Post Options Post Options   Quote Guest Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 06 at 8:58am
Just get a boat with a wire
Post Options Post Options   Quote Prince Buster Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 06 at 8:55am
After a windy sail in my laser my knees were almost dying and i could barely walk.  If I carry on like this i think I'll be in a grannymobile by the time i'm 30.
So.....are there any hiking boats (single-handed or double) that are easier on your knees to hike from than a laser, ie. dont do so much damage?
Thanks,
PB
