Going down the mine ... |
Page <1 2345> |
![]() ![]() ![]() ![]() Posted: 09 Dec 05 at 1:54pm |
Bow too far up is slow however. The boat starts pushing water out of the way instead of skimming over. How much is right is very dependant on boat shape and also survival - 15 knots and no pitchpoles is probably faster than 30knots and two pithpoles per downwind leg
ding33 ![]() Newbie ![]() Joined: 09 Dec 05 Online Status: Offline Posts: 5 |
Have recently started sailing an 18 ft skiff and can report bow definately lifted by the kite! Scariest move is bear away (slow speed, no kite up, so big potential for nose dive). Apparently, biggest crashes are when bow is lifted so much that boat gets fully airbourne and then remembers it can't fly and comes crashing down bow first. Trick is to flog kite over biggest waves to avoid this.
But which is more fun ... |
Yep I agree with all that you say, the sheeting out may relate to slight loss in power causing you to return to the water quicker. either way it worked, and bringing the rig slightly to windward increases air time!! And one thing is for certain its very complicated!! ![]() |
Its debatable which is the most fun, but I know which in the long run is the most expensive... |
Crew on 505 8780 |
It is tricky to say if the kite lifts the bow it certainly can as the
boat jumps waves, however it definatly pushes the bow down less than
the mainsail/jib combination.
If you work out the vectors for the where the kite attaches, then for a verry short mast and a verry long pole the kite would lift the bow. I think that a more significant effect comes from where fore and aft the driving force comes from, with the main/jib it comes from about hounds height above the mast step. with the kite up I think it comes from a bit lower down but much further forward possibly in front of the bow. This makes a difference in the torque link between the driving force and the drag force, which acts to push the bow down, this force is less the larger the distance fore and aft between the drag and the drive. |
Gotta agree with Granite that the shape / vectors control this. I've a Very tall thin kite and do not get a great deal of lift (but better than nowt).
Check out
http://www.sailworks.com/04-05/pages/video_gallery.cfm A minute or so in, the guy starts jumping. Check the attitude of the rig when he is going for the biggest jump, compared to the attitude of the rig when he is sailing normally. |
Bumble ![]() Far too distracted from work ![]() ![]() Joined: 12 Nov 05 Location: Taiwan Online Status: Offline Posts: 302 |
MMMMmmmm..... what a hunk Dale Cook is.
i am but a humble feva sailor so i do not have any experience of playing with realy big kites. however when we get a SW breeze blowing up the western solent it piles up the waves and we get tremendous surfing conditions which gets our small kite easily on the plane. the trouble occurs when we chicken out because its too windy and we quickly realize that with no kite the feva goes bow down in the big waves off Hill Head very quickly. when the kites up the bow does still go into the next wave but the boat does not burry itself past the shrouds in water. therfore i have come to the conclusion that kite = lift of bow = no nosedives
Page <1 2345> |
