New Posts New Posts RSS Feed: Round Sheppey- roll call
Post Options Post Options   Quote Guests Quote  Post ReplyReply Direct Link To This Post Topic: Round Sheppey- roll call
    Posted: 04 Sep 11 at 2:17pm
The wind conditions were just about perfect, shame you couldn't make it Graeme. Mike is too modest to point it out, but he was first monohull over the line by quite a distance and first monohull on handicap. There was a Tornado that flew around and won overall and couple of Scorpions that did well too, as well as a couple of sailboards.
oldarn View Drop Down
Post Options Post Options   Quote oldarn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 11 at 4:54pm
Mike did start 30 minutes before the Osprey, Canoes and AltO which went round fifteen minutes or so faster! But still a great result Mike.
thefastexcitingrunningasymmetric
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 11 at 5:28pm
Originally posted by RS400atC
. It's sort of ironic, the faster the boat, more likely to have a daggerboard and cassette rudder, more able to do damage by grounding.
Not ironic at all. The faster the boat the more likely you are to rip the whole damn lot off the transom if the rudder blade comes up a bit.
RS400atC View Drop Down
Post Options Post Options   Quote RS400atC Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 11 at 7:58pm
I think the force of a grounding at speed will tend to be greater than the hydrodynamic force the rudder can generate. Sand and Granite being less fluid/more viscous than water!
I've had a few experiences of kicking the rudder up on the 400 at speed, kite up, the load on the tiller goes through the roof until you switch into steering with the main. It's not quite so fast, but it's quicker than capsizing!
I am a convert to clamcleat self-releasing rudder cleats, I suspect they've saved my rudder blade a couple of times.
At least the ICON's gudgeon broke rather than structural hull damage, which is so often the case.
Back on the water next weekend?
Post Options Post Options   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 11 at 8:38pm
It was the rudder stock that broke, the boat itself is all fine as is the rudder blade. I'll be back on the water as soon as the stock can be re-welded.
Edited by Peaky - 04 Sep 11 at 8:39pm
Post Options Post Options   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 11 at 11:13am
Our low tech solution was shock cord fitted as part of the rudder downhaul....where we did make contact it seemed soft apart from the corner into the swale, very dodgy there.
Edited by GK.LaserII - 05 Sep 11 at 11:18am
alstorer View Drop Down
Post Options Post Options   Quote alstorer Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 11 at 11:19am
Apparently the IoSSC Ospreys 9and possibly other boats) were well stocked with spare plastic shear pins (or rather, sawn up biros...)
Al
