LASER MAINSHEET |
Page <1234> |
![]() ![]() ![]() ![]() Posted: 09 Feb 11 at 7:30pm |
Yes 6mm is the best diameter for a Laser mainsheet.
RobbieP94 ![]() Groupie ![]() Joined: 27 Aug 10 Location: United Kingdom Online Status: Offline Posts: 47 |
yeah thanks for all the help
i was going to use Evolution Swift 4mm for all the control lines any views on this? |
Laser GXD 184358
I14 1395 (crew) RS200 352 (crew) Coribee Keelboat (helm) |
We have actually moved to far thinner control lines - 2.5 mm. We can supply a compete pack (Mainsheet, Traveller, Outhaul, Downhaul, Kicker) for £35. Hope this helps, Jon.
Hughph ![]() Far too distracted from work ![]() ![]() Joined: 13 Oct 10 Online Status: Offline Posts: 324 |
Where can is this available? Currently my set up is a vectran V12 traveller, 7mm politite mainsheet, Rooster supplied 6:1 outhaul and a 10:1 downhaul- unsure of rope brand... Is there anything really worth replacing rope wise? Cheers PHS
Vectran is fine if it is actually Vectran but does it burn? If it doesn't (the ends don't melt) then it contains Aramid Fibre which is specifically not allowed in the class rules.
Vectran also dislikes the sun making it a bad choice for the Traveller. Just think how much sun the Traveller gets! I like the Rooster Politite mainsheet a lot and I have still not found anything better, although I use the 6mm sheet, as I beleve it goes through the blocks better. For the control lines we are using primers which don't flatten and low stretch and softer ropes for the secondary lines (very similiar to what a lot of people use for mainsheets). Getting the right ropes is really important so we are taking our time to get the lengths, materials and thicknesses spot on (I am sure you understand how important this is and we want to get it right first time) but it will be available soon. The aim is to have produces which last and function better. I would definitely replace your current set up WHEN they were out (remember ropes do not last for ever and you shouldn't just keep using them until they break!) Hope this helps, Jon |
Any reason why they banned it? Cheers PHS
Edited by Hughph - 27 Mar 11 at 10:49pm |
You can see what I am using as a traveller set up here (it is a Dyneema SK75 line with a hard wearing outer cover):
http://jonemmettsailing.co.uk/index.php?page=latest-blog The reason Kelvar type ropes are now allowed by the class rules is that they "do not like going round corners" meaning they can suddenly break... not a good thing when you are in the middle of a race!!! |
Guessing that is 4mm, might order some of Marlow or somewhere similar,
However there seems to be a huge fluctuation in prices between manufacturers? Cheers PHS
Surely if a rope type is unsuitable due to risk of breaking, it can be weeded out by that rather than having a bureaucratic block put on it in class rules?
Al |
Unfortunately not everyone realises the potential problems and therefore may avoid using a better but more expensive solution such as Dyneema. So in a way the class rules are there to protect the sailors.
We are actually looking at two different manufacturers one Italian and one British to try and get the best deal for Laser Sailors. |
Page <1234> |
