New Posts New Posts RSS Feed: Beginner boat choice advice please
Jack Sparrow View Drop Down
Post Options Post Options   Quote Jack Sparrow Quote  Post ReplyReply Direct Link To This Post Topic: Beginner boat choice advice please
    Posted: 04 Nov 09 at 4:43pm
Single trap:
Buzz ( small class now, but a great boat ) I'd go for this one.
Laser 3000 / Laser 2 ( class not as big as once was )
420 ( your a bit big but not much )
Hiker:
RS200 (more money than your budget but worth it)
Lark (big student following - lots of drinking)
GP14 ( a bit more family focused )
You'll be fine going straight into boat ownership / sailing with rescue
cover. Sail in the light winter winds and build up you skills as you go.
edit: 140kg is fine for all these boat. A bit heavy for the 420, but you are
learning so it helps to be over rather than under weight. As your skills
get better you can go up the power to weight range.
Edited by Jack Sparrow
portlandboy View Drop Down
Post Options Post Options   Quote portlandboy Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 09 at 6:54pm
if I had a choice I think I'd rather go for a hiker with assymetric gennaker than a boat with trapeze and spinnaker. RS200 does look the business but nothing below £3k...if there was general feeling amongst you all that it would be an ok choice I'd perhaps stretch the budget and go for one.........
winging it View Drop Down
Post Options Post Options   Quote winging it Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 09 at 7:46pm
I think you'll be pushed to find one for what you've said want to spend but speaking as an SI, I think an RS200 would be a great choice for two keen, fit beginners, so if it's what you want and you can find the extra money, go for it.  I'm pretty sure if it didn't work out you'd have no trouble selling without much loss.
radixon View Drop Down
Post Options Post Options   Quote radixon Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 09 at 8:27pm
200 is the best boat I have sailed as a double hander to date. Really comfy, easy to manage/handle etc and loads of following.
(I did say sailed to date , not sailed everything though)
Post Options Post Options   Quote portlandboy Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 09 at 9:52pm
Looks like we're going to be in the market for an RS200........unless anyone thinks that's a really bad idea. Now to break the news to the missus
Cheers for all the replies so far. Any more input most welcome.
Rich
martin555 View Drop Down
Post Options Post Options   Quote martin555 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 09 at 11:07pm
RS200 is a great boat, the best thing is they hold there value, so you can sell it if you do not like it. Its tippy when windy though
womble12345 View Drop Down
Post Options Post Options   Quote womble12345 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 09 at 10:25am
I agree with the comments of looking at what classes are sailed at your local sailing club (Castle Cove would seem the obvious choice). I understand why you would prefer an assymetric as they are simpler. At 140kg you will be at the top end of the competitive weight range for an RS200, although they will happily carry much more. They are quite tippy though and a bit unforgiving to slight mistakes that a beginner may make, if you are keen and don’t mind a bit of swimming you will certainly grow into it though. If you fancy something a bit more forgiving then the Laser 2000 could be better.
However I don’t think you should write off symetric kites, there are a few Scorpions at Castle Cove, they are more forgiving than an RS200 and are within budget but the boats in budget are going to be wood. I just had a look at the castle Cove website as the results section should provide some information on what the bigger fleets are but unfortunately they just list the sail numbers, not the classes!
ellistine View Drop Down
Post Options Post Options   Quote ellistine Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 09 at 10:34am
unfortunately
Good idea. If you click on the sail number it will tell
you the class (you may have to enlarge the window
slighlty).
The website doesn't list the Laser 2000 as a preferred
class even though it is the most active class. I think
they decided not to give it the kiss of death by making
it official
I think there is possibly a couple of RS200's although
one of these belongs to the Navy. The other is a regular
racer. Infact as the PY of the 200 is only one different
to our Vago, he is our closest competition.
Edited by ellistine
Mister Nick View Drop Down
Post Options Post Options   Quote Mister Nick Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 09 at 7:51pm
Hmm, a topaz vibe would be a good option if your looking for something that you can bash around a little bit without having to worry too much about damaging it. An RS Vision would be good for this purpose too.
If your looking for something a bit quicker then go for a Buzz or similar
tickler View Drop Down
Post Options Post Options   Quote tickler Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 09 at 11:06am
Just get a Tasar.......they just do it all.
