New Posts New Posts RSS Feed: Downwind in Shifts?
Downwind in Shifts?
Oli View Drop Down
Post Options Post Options   Quote Oli Quote  Post ReplyReply Direct Link To This Post Topic: Downwind in Shifts?
    Posted: 24 Sep 09 at 3:06pm
I always hear about people timing the shifts upwind, never held much in it myself, wind doesn't oscillate with precise regularity as far as I'm aware.  Anyway if you time the shifts upwind then they will be the same downwind, so just keep the timer going and go on the beep.  personally I'm looking for pressure which usually comes with a shift anyhow.
damp_freddie View Drop Down
Post Options Post Options   Quote damp_freddie Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 09 at 2:21pm
good youtube...god those guys are skilled!
gybing on the lifts and finding wind bends is all said and done, but in a big pusher apparent wind boat, like the I moths or the 9er boats then riding the gusts and staying under pressure with an eye on the mark is more appropriate - given there are no extremes!
In a blaze or an RS400 you are going to have a good tactical race 'tacking downwind' but as stated above, a lifting gust can be deceptive- you sail deeper but could have a double pluss by gybing on it.
Wind shifts are often associated with either higher or lower wind speed. This is why top teams take the time to go up the course on long, loing tacksand shoot head to wind a few times. Just reverse the pattern for offwind.
timnoyce View Drop Down
Post Options Post Options   Quote timnoyce Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 09 at 11:24am
That footage is epic Grumph, not often duels like that get captured for their entirity.
getafix View Drop Down
Post Options Post Options   Quote getafix Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 09 at 9:43am
imagine you're on a 'sausage' course, you've got lifts and headers upwind so you'll also get them downwind, how do you spot 'em going downhill? just like sailing upwind, when you're going down the deeper you can run at a certain spot would be the equivalent of a header going upwind, while the higher you have to point would be the equivalent of a lift going upwind, same factors which "generate" the shifts upwind will also do the biz while you're going downhill, i.e; clouds, gusts, land features.... try to "map" them in your head by spotting land features you can then try to aim for, or avoid, when going back upwind depending on whether or not it's a header or lift
like mr perkins above says, it's about pressure and feel downhill, although you can see the gusts coming and may be able to sail to the lifted side if there's boats behind you switched on enough to be sailing to them as they come through
Guest View Drop Down
Post Options Post Options   Quote Guest Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 09 at 9:36am
To answer your question I never look at the compass downwind.
Usually there are big angle changes with presure and they are pretty obvious to see/feel.
G.R.F. View Drop Down
Post Options Post Options   Quote G.R.F. Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 09 at 9:27am
Shifts are very important downwind particularly if you're racing something
like this
hum3 View Drop Down
Post Options Post Options   Quote hum3 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 09 at 9:07am
Originally posted by chrisg
I dont think shifts are as important downwind, but gusts are....
Ooooooh... That totally depends on the type of boat you sail, and the prevailing conditions.
In a relatively slow assy boat like the 200 where you have to gybe downwind through relatively large angles, downwind shifts and gusts are very important, especially in dispalcement conditions.
A lift tends to announce itself by the pressure in the kite starting to fall when you haven't changed direction (compass useful to confirm that). As you want to sail on the headers downwind, that's usually a sign to consider gybing.
A puff will feel like a header as the apparent wind comes forward as it increases. You can sail lower until the boat has fully accelerated - then you might have to come back up close to the original heading.
In planing conditions, pressure is king. If the shifts are big, (such as a wind bend) they MIGHT come into consideration, but usually I'd choose pressure over the shifts in those circumstances.
EDIT - correction!
Edited by hum3
Post Options Post Options   Quote G.R.F. Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 09 at 9:05am
Well even when rowing our flappy air oars, there's always a tack that's
more effective (It's easier to pump higher than lower for a start) so it's a
no brainer selecting the tack on a board and gybing is obviously a lot
easier and more accessible if you are air rowing in lighter conditions. In
fact rather like dinghy roll tacks we invented a multiple gybe pump action
back in the day when the legality was dubious.
Whatever we digress, so what y'all are saying is you haven't a clue - yeah?
And even if you had those gizmo thing you wouldn't know what to do
with them either?
Tell me you would still take the tack that taking you closest the mark at
least.. doh.
Post Options Post Options   Quote Guest Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 09 at 8:55am
It's all about feel; you will develop it in time ... you probably havn't noticed subtle wind changes whilst flapping your air oar around ...
As stated above in a fast assy it's all about presure more than wind angle.
chrisg View Drop Down
Post Options Post Options   Quote chrisg Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 09 at 8:47am
I dont think shifts are as important downwind, but gusts are. I spend the whole time looking for darker patches of water and aim for them. But i'm not very good so someone who knows what they are talking about might know more....
Edited by chrisg
