Is inflation impacting Nationals Attendance? |
Page <1 21222324> |
| Author | |||
Sam.Spoons
Topic: Is inflation impacting Nationals Attendance?Posted: 05 Sep 22 at 1:35pm |
Yes, that was always the story but with the present system where a pathfinder gets a net 3-5 lengths head start and clean wind up the whole beat the 9th place boat is likely to play the same games...
Fatboi
Joined: 09 Aug 16 Location: Hampshire Online Status: Offline Posts: 189 |
Posted: 05 Sep 22 at 2:33pm |
Except you cannot take advantage of any shifts, go left if favored and have to hike for longer. I would still dodge being path finder rather than be it given the chance...
Paramedic
Joined: 27 Jan 06 Location: United Kingdom Online Status: Offline Posts: 929 |
Posted: 05 Sep 22 at 4:24pm |
But you do get a clear lane for the first two tacks of the beat
Edited by Paramedic - 05 Sep 22 at 4:25pm |
MikeBz
Joined: 21 Apr 04 Location: United Kingdom Online Status: Offline Posts: 536 |
Posted: 05 Sep 22 at 7:03pm |
If you offered anyone in the top 25% of the fleet the opportunity of being pathfinder tomorrow I very much doubt they would take it, even under the current format. Taking a flier on the first beat is just too risky, more so without it being a considered decision based on the actual conditions of the day.
Mozzy
Joined: 21 Apr 20 Online Status: Offline Posts: 209 |
Posted: 05 Sep 22 at 8:45pm |
The argument about whether people tussle for tenth place cuts both ways.
You do need a willing pathfinder to have a successful start though. A few boat lengths of grace removes a bit of urge to drop the mainsheet with a 5 degree knock. There's no evidence that it's a big advantage. And if it's a small one, it's one that only happens once a regatta. Personally, I would gladly take the point off 9th place and take my chances competing for clean air on a part of the course of my choosing. Very few people make the top ten sailing in dirty air, so I am not sure many would view sailing in clean air for the first 4 minutes as a massive advantage. However I am pretty sure very few boats in the top ten sail the first 4 minutes on the same tack regardless of lift or header. Another way of looking at it is, if you can't make 2 boat lengths on a boat that can't tack on shifts... then, well, top tens probably aren't your event target. Being ahead of the pathfinder at the first cross should be 'par' for any top boat (this is actually a good exercise I used to do in coaching, especially those new to 29er to work out what shifts they should be tacking on).
Edited by Mozzy - 05 Sep 22 at 8:51pm |
Sam.Spoons
Posted: 05 Sep 22 at 9:29pm |
How long is a typical first beat? Lets say 1 mile so, in most boats, no less than 15 minutes. The RYA suggest that 3 minutes is the max line length before the PF can tack away. Sure he's forced to go left for 3 minutes but then he has clean air and can choose to tack at will. I'll accept that there is a small disadvantage for that first 3 minutes but after that, unless the right side is clearly favoured, he still has clean air and is free to choose from not too far left of the middle of the track. Gybing round behind the gate boat seems fair to me, if it's so windy that you can't gybe reliably it's probably a lottery anyway, but maybe the advantage of tacking is equally small and compensates for been tied to port tack for that first 3 minutes.
Consider this though, you are 2nd or 3rd row of a line start but able to tack off immediately into clean air, would you tack or play the shifts close to the other boats? I know what I'd do, 3 minutes on the wrong tack but in clean air is usually preferable to 3 mins on the write tack but buried...
deadrock
Joined: 24 Jun 08 Location: United Kingdom Online Status: Offline Posts: 85 |
Posted: 05 Sep 22 at 9:38pm |
Sailors have strategically avoided the 10th place only to be bumped up a place or two due to DSQs by their betters (in that race). One can be too clever by half....
Mozzy
Posted: 05 Sep 22 at 11:12pm |
Sounds a no brainer for someone finishing mid fleet. But starting 2/3rd row isn't normally in the race plan for a boat finishing top ten. For the pathfinder I think the advantage is small when it's there, but more often than not the boat in question would be better taking their chances with top ten boat speed in a place of their choosing. And the results back that up. People seem happy with it. Apart from in special circumstances I would never give up a point to be pathfinder. |
sargesail
Joined: 14 Jan 06 Location: United Kingdom Online Status: Offline Posts: 1459 |
Posted: 06 Sep 22 at 5:49am |
I have been Pathfinder once….two runs……on the first pressure and a couple of shifts meant that there were a couple of boats almost paralleling us and abeam at about 3 minutes in to a 5 minute gate. That start was abandoned….it illustrates that the disadvantage to the pathfinder could be enormous, and that the micro gains are going on all the time for boats unconstrained.
davidyacht
Posted: 06 Sep 22 at 7:18am |
I have been pathfinder and led at the windward mark, so it cuts both ways. I prefer gate starts in big fleets, it removes a whole element of faffing around. They deskill the start a bit, but hanging around for the perfect line start can be a big disincentive to attending championships. I do think that when they are used the first beat should be a long one, otherwise the more level start means that the windward mark can be unpleasantly busy, particularly when short championship races seem to be derigeur
Edited by davidyacht - 06 Sep 22 at 7:19am |
Happily living in the past
Page <1 21222324> |
