Laser Tips |
Page <123> |
EmmyC ![]() Newbie ![]() ![]() Joined: 30 Oct 10 Location: Berkshire Online Status: Offline Posts: 39 |
![]() ![]() ![]() ![]() Posted: 10 Jun 12 at 5:55pm |
Hi guys.
I took on all the advice you lot gave me and I got block to block with no trouble. I now, however, have another problem: There is far too much going on at the mast and things are getting into the way of other things - Making sail control hard. Is there an order I should rig things up in in so that there are no problems? Also, how do I stop the outhaul blocks getting caught on the clew strap? Thanks ;) Edited by EmmyC - 10 Jun 12 at 5:58pm |
You can always 'end for end' the top mast (unless it has already been done) just make sure the bent bit points forwards unless you straighten it first.
With the mainsheet if you pull it out the boat and slowly walk along it whilst gripping it fairly tightly until it is fully extended this can help with the kinking and tangling. I do this twice before tying the loose end off at the mainsheet ratchet, it does help.
Thanks for the help - I imagine ringing out the mainsheet will help as it tangles non-stop. The top-mast was bent when I bought the boat - I have been putting off buying a replacement for a while due to the fact my priority was the Harken kicker. I had no idea that a bent top mast made such a difference? |
Don't worry about that. Lasers are pretty strong and stand up to a lot of abuse. Do inspect your spars and fittings regularly and as soon as they get loose re-rivet them.
Yes, but by bending the mast with the kicker it is easier to get the mainsheet block to block. It shouldn't be hard anyway, just much easier with the kicker on!
I struggle to understand this post. I thought there was only one way to go block to block and that's to pull the mainsheet in. Then, whatever kicker is fitted you take up the slack on it. The higher purchase on the modern kickers only makes it easier to pull the kicker tighter than this basic setting.
PeterV
I would suggest a list of things to do would be
1) fit the new harken kicker, be careful not to use too much with all that extra power! 2) tie the end of your existing mainsheet to a fence post or similar, run the rest through your hands and "ring it out" until you reach the other end. Like a skipping rope except not round in circles, just randomly shake it. That should help get the twists out. 3) if twists continue try a new mainsheet 4)regularly check your top mast for bends, a bent mast is firsly slow, and secondly not legal under the class rules. 5) occasionally check the bottom section for bends, i have seen radial bottom sections bend where the sleeve ends on the inside. Somewhere just above the gooseneck i think. 6) if all else fails PULL HARDER! ![]() If you have any other questions just ask. There are loads of tweaks you can do to the laser to make it much more fun to sail without being illegal. Most are free/cheap to do. Just ask!
I have the Radial which I use most, however I will be purchasing a 4.7 rig for those windier days. I have quite a lot of upper body strength, although most of the time I'm scared of breaking something!
Which rig are you using? The 4.7 is easy to get to block to block with no kicker because of the bent mast, the radial is a little bit harder but because a large amount of the mast is top section which is really bendy it shouldn't be a problem. The full rig can be a bit hard if you aren't a gorilla!
The kicker will help but don't get lazy and just use that to pull the boom down, it will bend the bottom of the mast far too much and flatten the sail and you will go slow. Best practice is to have the kicker on just so it isnt slack when it is about 10 knots of wind, then as it builds keep pulling and pulling to flatten the sail. An important thing to remember with your new kicker will be to let it off when you are sat around between races etc and to ease it enough on reaches and downwind. If you don't do this you will find yourself bending a lot of top sections! As said, the most common mainsheets these days are about 7mm, rooster polylite or similar. That said, when I finished lasers I was using a development version of the Laser red fleck mainsheet which is slightly under 6mm. There were a number of versions of that sheet and if I remember rightly Paul Goodison took the yellow fleck version to the olympics where it was light wind, this was about 5.7mm there was a white fleck and a green fleck version too i think. I quite liked the thin mainsheet but others would definitely disagree! If in doubt use the rooster 7mm sheet.
Thanks Jeffers - I did try that once or twice but I was far too slow and kept heading into wind quickly - I guess that may have to be something to perfect!
Page <123> |
