Laser radial |
Page <12 |
Hughph ![]() Far too distracted from work ![]() ![]() Joined: 13 Oct 10 Online Status: Offline Posts: 324 |
![]() ![]() ![]() ![]() Posted: 30 Apr 11 at 9:17pm |
That would be a good idea but it is pretty singular... You'd ideally want a bigger range of excercise in order to not overly build one muscle group to the detriment of others?
Anyway, here is my workout I use for the Radial over winter when I'm not rowing. Though it would work all year round I have a rowing fitness program over summer
Here is the gym program- Workout 1
Exercise Sets
Reps Weight A1 Poliquin Step up 3 15-20 A2 Back Extension 3 12-15
B1 Pull Up (Towel) 3 Max
B2 Incline Dumbell Press 3 12-15 10kgs* (in each hand) C1 Wall Sit 3 Max
C2 Plank 3 Max Workout 2
Exercise Sets
Reps Weight A1 DB Squat Heels Up 3 10-12 6kgs* ( in each hand) A2 Split Squat Front
Foot Up 3 10-12
B1 Inverted Row + Hold 3 10-12 B2 Cable Pull (Rope) 3 10-12 22kgs C1 Side Plank 3 60seconds C2 Plate Pinch 3 Max 5-10kgs How to use The 2 workouts are not for the same session- E.G You would do workout 1 on one day and then workout 2 the next- it is to balance things up a bit. I tended to do these in two day chunks with a rest day in-between each. The exercises are done in categories so you would have a 3min break between A,B,C In one set you do the number of reps it says and have a 30sec break in-between sets If you find it hard- and I definitely did- it helps to have a rest week ocassionally- maybe if your doing a lot of time on the water or before a big event. I tried to taper down to big events. * V Important- Do only the weights you can manage- don't hurt yourself but don't make it easy either. You can gradually move to heavier weights as your strength builds. Enjoy, Piers HS EDIT- Forgot to add- If you don't know the name of the exercise google it- I did.... Credit for the program to OC Fitness. ( I am a student at the college so he wrote it up pro-bono...) Edited by Hughph - 30 Apr 11 at 9:51pm |
If you join the UKLA you get a DVD which has all the basic sailing techniques you need to know....
Edited by Jon Emmett - 03 May 11 at 10:57pm |
Page <12 |
