shocks from mast?! |
Page <123> |
![]() ![]() ![]() ![]() Posted: 22 Jun 10 at 12:01pm |
Carbon conducts electricity, and around pylons there is certain amount of static electricity generated. When you pass the carbon inductor through the electric field a current will be induced, and since the mast is earthed (through either the tie down chains or the vents) that will allow the current to flow, and if you happen to be touching the mast at the time, then it will use you as the earth, seeing as you are a shorter route to the ground.
You're painting such a lovely image of you club, what with the electric shocks and sewage storage! |
Laser 203001, Harrier (H+) 36
Well... the clubs office manager obviously doesn't like me
so that being so, would it effect the mast long term? |
The answer probably lies with research done in the aircraft industry. |
Mikey 14778 ![]() Far too distracted from work ![]() ![]() Joined: 05 Feb 09 Location: United Kingdom Online Status: Offline Posts: 298 |
I recall that you can get enough electromagnetic energy under a pylon to light a fluorescent strip light, so there's certainly going to be a noticeable effect on something. Personally I very much doubt it will affect the mast itself, but I'd be a bit concerned about it affecting you. You might also find that it's inducing some nasty chemical reactions in the mast fittings. Find some way to earth the mast - a bit of wire from a stake in the ground to a crocodile clip that you can put onto a shroud or something. |
by earthing the boat properly, I'd suspect there's a rick you could exacerbate any electrolysis issues. As for the conductivity, as I said in the lightning strike thread, whilst carbon fibres are conductive, CFRP is pretty insulating. This doesn't though stop induction currents forming in the individual fibres. Boeing solved the conductivity issue in the 787 using metallic mesh- adding a lot more weight than anticipated. It worked though- a recent test flight got hit and they report no damage. On average, every passenger jet gets hit once a year. |
Al |
Speaking as a bona fide electrical engineer .....
There will be an electric field around the wires on the pylons. Your mast will attain the same voltage as the voltage in the field at the top of your mast. Normally it will be OK as the boat will insulate the mast from the ground (unless it's a metal boat!) and no current will flow. BUT, when you touch it, especially standing on the ground with (salty!!) wet feet, you complete the circuit and current goes through you and the mast. I don't think earthing the mast is a great idea - there might always be a (tiny) current flowing and, more to the point, it will turn the mast into a lightening conductor too. Whatever your problem, it would be worse with an aluminium mast, they conduct much better. But don't worry about the mast, worry about you! Chances are, the current is very small, cause as soon as you touch the mast the voltage will collapse. But if it hurts, it's not good. Get a new parking space!!! |
Javelin 558
Contender 2574 |
it hurt all right. Both me and my son. The boat is carbon also. Interesting a RS200 guy had had shocks on the same day. The weekend had a heavy pollen count so maybe high static charge? I don't know.
on a serious note, I would imagine Burghfield's club manager should be able to ask (aka force) the electricity company to check static around the base of the pylons is within safe limits on H&SE grounds and advise on whether or not certain/any boats can be stored there (if it is BSC, sounds like it)
Page <123> |
