speed difference between tacks |
Page <123> |
![]() ![]() ![]() ![]() Posted: 01 Jun 09 at 1:15pm |
This Sunday it was more a case of which tack gives you the most cooling breeze! |
Sometimes, the wind can get "stuck" in the sail: too much kicker / mainsheet tension / battern tension / fullness in the sail etc. You don't need much "too much" for the boat to be saiing slower than it could. Then you tack / gybe, and shake all the wind out, re-sheet, re-angle the boat, pick a wind shift, and get moving again. Happens ALL the time inland! |
Sailing on a lift almost always feels better than a backer.
If it's ALWAYS faster on one side than the other then it isn't tide or direction of chop or "stuck wind" (really ???) surely. Probably different length shrouds or lowers (measure them & check which hole in the shroud plate they're in) or failing that a rudder that isn't hung quite vertical or a warped centreboard. Boat builders aren't always exact in their placement of cleats, blocks and fairleads either Anything that's not symetric could do it. Including your crew's legs probably! |
Javelin 558
Contender 2574 |
I would disagree a tack where you are going straight into the chop is often slower than one where the chop is side on.
Rather than 'stuck wind', I would go with 'stalled sail'
Ex-Finn GBR533 "Pie Hard"
I'll start to check but I don't reckon it's always a port or starboard tack that's quicker (ie boat problems). I'm pretty sure it varies. The Sunday just gone it was easier to keep the crew out on the trapeze one way than the other. It probably is the tide. Being new to sailing I've been ignoring it but I suppose I'll have to start paying attention to it. Edited by ellistine |
If it was easier to keep the crew out on one tack than the other it may well be a pressure difference (sailing into/away from more wind). Tidal differences are still relatively gradual.
sailing at hythe, i find that in certain conditions wiring is much easier on one tack than the other i found this was due to differing angle of the current pushing on the foil, if you get the current pushing the foils the wrong way then the boat feels awful, but if you get it right the gains that can be made are quite supprising.
Laser 184084
Checking your mast is straight is relatively easy, for one way look at: http://www.youtube.com/watch?v=cSyrc3QUssE - there is no sound worth listening to with this video clip. Garry |
Garry
Page <123> |
