Laser Top Mast Changes |
Page <123> |
| Author | ||
Jamesd
Joined: 01 Feb 08 Online Status: Offline Posts: 377 |
Topic: Laser Top Mast ChangesPosted: 28 Nov 08 at 12:33pm |
i did read inthe latest laser mag, the measurer going on about recommending end for ending the top mast section. is this legal?
Alistair426
Joined: 02 Jun 08 Location: Vatican City State Online Status: Offline Posts: 201 |
Posted: 28 Nov 08 at 12:40pm |
Certainly is...lots of people do it. Doubles the life of the top-section...especially if it has already been straightened a couple of times.
Guests
Posted: 28 Nov 08 at 12:42pm |
It'll be interesting to see if this does reduce breakages. The mast will still bend but by rotating the mast the user can spread the bending over 360 degs...do that to aluminium and it will still break......
I would have thought making it out of a different material would be a better bet...same flex characteristics as ally but one that doesn't work harden. (please consider my sig when reading this Edited by GK.LaserII |
alstorer
Posted: 28 Nov 08 at 12:53pm |
Furthermore, for a piece under tension, if the hole is filled tightly by, say, a rivet, you actually see a further decrease in strength as the deformation of the material around the hole is adversely affected (but in compression, the rivet will take some of the force). |
Jamesd
Posted: 28 Nov 08 at 1:13pm |
they have been toying with composite ones for ages. Not sure if it is for all classes but was aimed at the radials and reducing the weight range for the boat. i presume by making it lighter and therefore less moment, as the bend characteristics are to remain the same as the ali, not to sure though. but the development has been postponed. crap idea though. Imagine a carbon top mast or glass for that matter from laser. they would want £600 |
Matt Jackson
Joined: 21 Sep 04 Location: Darlington Online Status: Offline Posts: 962 |
Posted: 28 Nov 08 at 3:20pm |
Sorry I disagree, if I remember correctly the mast always goes together the same way and in time bends in effect giving some pre-bend which changes performance. If the new system allows the mast to be put together any way then there will be less bend and less change in performance. Therefore the change will affect the performance of the boats with the new top section. Notice I didn't say whether performance will be increased or whether the change is a good thing or not - I just disagree the the asertion. |
Laser 203001, Harrier (H+) 36
Laser 173312
Joined: 08 May 07 Location: United Kingdom Online Status: Offline Posts: 416 |
Posted: 28 Nov 08 at 3:50pm |
Gary The idea of a carbon top mast has been 'put on hold' the moment and whilst I take your point about the work hardening I still think the top section would last much longer without the rivet forcing you to put the 2 parts together in a specific allinement. It also means you can end for end it each time you sail and so spread the wear about. Also thinking a little more about it, now you can use tape around the mast joint. You would be able to tape the collet to the LOWER section semi permanately and just slide which ever end of the top mast came to hand first into it. I agree that the sail probably won't change for a few years yet, but this could be introduced relatively quickly I would hope. Incidently what do most people do with their old tubes. Do they just throw them or can they be recycled. May be PS could give you a discount for PXing your old tube for a new one. They might not need so much raw ally if they did that and that would be good for the environment. Sorry that's a daft idea 'PS giving a discount' I mean. Edit There seems to be some confusion about this. I don't think the top section is changing at all. As I read it all that will happen is the 2 collars will be taken off it and replaced by a split plastic cup that the top section will rest in. Please correct me if this is wrong.
Edited by Laser 173312 |
Fraggle
Joined: 28 Feb 07 Location: United Kingdom Online Status: Offline Posts: 220 |
Posted: 28 Nov 08 at 4:05pm |
Old broken top sections can relatively easily be turned into booms.
Guest
Posted: 28 Nov 08 at 4:26pm |
I thought the booms were sleeved?
bert
Joined: 23 Apr 05 Location: norwich usually Online Status: Offline Posts: 584 |
Posted: 28 Nov 08 at 4:45pm |
only where the kicker is aqttached
Phantom 1181
Page <123> |
