New Posts New Posts RSS Feed: windsurfing kit
windsurfing kit
Splosh View Drop Down
Post Options Post Options   Quote Splosh Quote  Post ReplyReply Direct Link To This Post Topic: windsurfing kit
    Posted: 09 Mar 08 at 9:36pm
I'd reckon to start off with a 2004 ish onwards 120/125L board... probably like a JP xcite ride or a Tabou Rocket
Sail sizes are probably best to start with about a 5m and same age ish sail.
I'd recomend gettting down your local windsurf shop and asking a few questions, or maybe ask some more experienced windsurfers at boards.com
Hope this helps,
Mark.
RS300 - 346 :D
Kudlinski View Drop Down
Post Options Post Options   Quote Kudlinski Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 08 at 9:14pm
I hate to say it but would a fanatic viper suit, higher volume and wide with a daggerboard, or am I just getting boring
RS400 866
RS300 381
tmoore View Drop Down
Post Options Post Options   Quote tmoore Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 08 at 9:11pm
thanks for the advice everyone. so am i looking for an older or younger board than that? or just a wider one?
what sort of volume does the board want to be (if im say 75kg to be safe) - about 105 - 115?
and then what sort of size sail? if i can get a board to match how does ASok's mast/ sail look for a beginner?
thanks tom
Landlocked in Africa
RS300 - 410
Firefly F517 - Nutshell
radixon View Drop Down
Post Options Post Options   Quote radixon Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 08 at 8:02pm
I second what Splosh said.
A 6.0mtr sail and a 113 ltr board is for those pros that you see diving around the cost jumping waves.
I would recommend for a beginner around 160+ ltr and about a 5.0 mtr for thos windy days if not less.
I am suprised MerlinMags didn't pimp the boards.co.uk forum (y+y sister mag!)
I would wait for a better option to be available
Post Options Post Options   Quote Splosh Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 08 at 5:06pm
Tom,
 I personally wouldn't recomend that board for a newbie to the sport. Nowadays most boards are going short and fat because width mean stabillity. Older boards like the mistral flow are very narrrow and reasonable heavy. Each litre of volume in a board can carry 1kg of man and a oldish rig can weigh about 20kg (ish?)  so that doesn't leave much weight for the rider (you). Also from experience of the flow it has very sharp rails meaning had to carve and not as smooth planing also it has less volume by the straps where you want it and more up front becuse of the long nose.
Also i reckon the sail will be on the large side for contidions when its too windy for the 300. I use a 5.8m in anything between F4-6 and a 4.7 for F6+
I weigh 10stone 2, and had just about float around on a 104L board and i also have a 111L slalom (very, very short and wide!) board. I use between my 4.7m sail and my whopping 8.9m which is a heavy beast.
Mark
RS300 - 346 :D
ASok View Drop Down
Post Options Post Options   Quote ASok Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 08 at 4:36pm
I've got a nice Tushingham carbon mast (40%) in really good nick that I can do you a good deal on.
Also, gathering dust in my garage is a 5.2m2 sail.  Also hardly ever used - I'm far to heavy.
Message me if you're interested.  I need to start clearing out toys that I don't use that much!!!
Chris Bridges View Drop Down
Post Options Post Options   Quote Chris Bridges Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 08 at 4:09pm
Originally posted by tmoore
will this depend on weight??? if so, im almost 11stone. but i should be steadily gaining weight.
i was thinking of possibly getting just the one sail (as advertised) then buying/ trading/ selling etc once i know what i want/ need. i wont just use it when its to windy for the 300 but whenever i can tbh.
Um yes but also strength and experience.. And fitness I guess too..
I can't get on ebay, what size sail comes with it?
Maybe try other peoples equipment for different wind strengths and see what size sail you want from that.
MerlinMags View Drop Down
Admin Group
Admin Group
Post Options Post Options   Quote MerlinMags Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 08 at 4:05pm
There are plenty of secondhand boards and sails in the Windsurfing section of our classifieds - www.yachtsandyachting.com/classifieds
Definately a good idea for days when it is classed as too windy to sail.
Edited by MerlinMags
Post Options Post Options   Quote tmoore Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 08 at 3:11pm
RS300 - 410
Post Options Post Options   Quote Chris Bridges Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 08 at 1:58pm
You need a couple of sails really (different sizes), or just a smallish one if its for windy days only.
