RS600 Mast |
Page <12 |
![]() ![]() ![]() ![]() Posted: 06 Dec 07 at 10:25am |
It's OK thanks, I've got a new plug just can't get the old one out.
RS600 1001
Is it Aluminium or plastic?
If aluminium put it in the freezer for a few hours the ali will contract more than the carbon and should then be able to get it out using the wood post method. Even if it is plastic this may help make the plastic more brittle |
get a bigger hammer! i like the freezer idea, but i doubt that a few degrees drop in temperature will make that much difference to a solid lump of aluminium. |
Also International 14, 1318 |
Shouldn't take much contraction to loosen it off.
RS600 988
hope you got a big freezer (8m long ish?) |
Landlocked in Africa
The bottom 18 inches of the mast comes off for reefing purposes, so it's in the deep freeze nestling amongst the fishfingers right now! |
RS600 1001
tedm ![]() Posting king ![]() Joined: 20 Sep 06 Location: Chester Online Status: Offline Posts: 174 |
You'd be suprised how much difference it makes. I've used this method before to 'shrink' much heavier pins that go through engine pistons and it def works. Standard practice. |
Granite you're a genius - it worked a treat! Thanks! |
RS600 1001
I'll stand corrected then.
Page <12 |
