Another which boat... |
Page <123> |
Fraggle ![]() Far too distracted from work ![]() ![]() Joined: 28 Feb 07 Location: United Kingdom Online Status: Offline Posts: 220 |
![]() ![]() ![]() ![]() Posted: 14 Nov 07 at 9:19am |
Quoted the wrong thing and then couldn't delete it d'oh!!
why are you quoting yourself?
![]() and just duck some more during tacks ![]() |
Cheers for that one - I seem to hit my head on my lasers boom often enough as it is! |
Fraggle, Your size and weight will be OK for the 300. You might be a bit light of the B rig but you can always reef that if need be which brings it to the same size as the A rig. The rig is very easy to depower. After a few sails you will soon find that throwing weight around in the boat won't help and that's it all technique. Why not get the adresses of those 300's at your club and write to them offerring money? You never know. But of course, try all the boats before you buy. |
Duck |
Well I now have a go in a Europe lined up for this weekend - any tips that I should bear in mind?
Have just emailed one of the Europe sailors to see if I can have a go in his - I sail at Weston so we do have a few. Won't be so easy to try a RS300 again as only 2 here and think they both have big rig but hopefully get a try in that again too. |
moomin ![]() Groupie ![]() Joined: 19 Jan 05 Online Status: Offline Posts: 60 |
Just like to dispell a myth about the europe boom height, following a discussion with a radial sailor at the club we measured it. During a tack when the helm is crossing the boat there is more room under a Europe boom than a laser. This is because the europe cockpit is deeper and with the new XD kicker systems the laser boom doesn't lift during a tack. The europe is sailed upwind without kicker, the same as the OKs and Finns so during a tack as the mainsheet tension is released the boom lifts. Anyway enough of that, I might as well add a completely biased opinion whilst I'm here because that seems to be the done thing, so try a europe, it's the best boat in the world, perfect for somebody your size. Contact the class through the website I'm sure we'll be able to sort you out a test sail. www.europeclass.org.uk Moomin Europe GBR391 |
Give the Europe a try.
If you are used to low booms ... There wont be too much of a difference! |
TandyUK Servers |
im around the same weight but taller...
i was told that the 300 was the wrong boat for me, but now i have proved them wrong and thats with the big rig on the 300 which im a good few stone to light for, so if the 300 was for you go for the smaller rig |
Page <123> |
