What rig? |
Page <12 |
![]() ![]() ![]() ![]() Posted: 07 Aug 07 at 10:44pm |
I'm sorry but i have to agree with dave there |
RS600 988
Moose ![]() Newbie ![]() ![]() Joined: 07 Aug 07 Location: United Kingdom Online Status: Offline Posts: 5 |
Yes, I mean three feet, not three inches English Dave, you are correct about putting rudders on outriggers and using a connecting bar as a handlebar but not about your thoughts with the centre mainsheet. I want one so I can jamcleat it to something and yet be able to release it quickly if necessary. I'm not familliar with the Laser2, but will do my homework. I wondered if a mirror rig would be a bit small? You think I'm mad and you don't even know me! You should hear my friends' opinions! Cheers, Moose |
Sails a half-decker on the Norfolk Broads.
Might be a bit big... Maybe Topper or Mirror... Presumably you mean three feet beam rather than inches! Edited by JimC |
Hi Moose welcome to the forum. It depends what sort of sailing you are going to do. If you are cruising the broads then an easy handling sail would be best. I guess you want the centre main because you are seated facing forward? Something like the sail from a Laser2 would do you. You might be a little overpowered downwind depending on where you site the mast. Perhaps a Mirror gaff rig might also be worth considering. Cats need two rudders because they sail on only one hull at a time. Perhaps I'm wrong but I don't see this happening with your project. Oh, do you mean put them on the outriggers and use the connecting bar as a sort of handlebar? An unstayed mast would load up the canoe hull but it would save you from having to over-engineer the bracing that will hold the outriggers. Good luck but I think you're mad! |
Hi all, I'm currently thinking about converting a canadian canoe to some sort of outrigger canoe/trimaran thing and was wondering what rig to give it. The canoe is 13' 9" long and just under 3" wide. I was wondering about a laser rig? I sail on the broads, so I need a rig with halyards, not a sleeved main. A centre mainsheet would be ideal. I was going to buy 2 laser rudders and connect them together in a twin-skeg config, like seen on fast cats. Plz reply soon!
Page <12 |
