New Posts New Posts RSS Feed: 59er Sails - very flat
Jon Emmett View Drop Down
Post Options Post Options   Quote Jon Emmett Quote  Post ReplyReply Direct Link To This Post Topic: 59er Sails - very flat
    Posted: 18 Apr 07 at 7:59pm
The reason the 59er has much flatter sails than the 4000 is also due to weight (the 4000 sails need more power to pull all that weight through the water!!!)
swiftsolo.org View Drop Down
Post Options Post Options   Quote swiftsolo.org Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 07 at 11:13pm
Make sure you have the lowers pulled on so the bottom of the mast is dead straight when you apply rig tension.
We basically couldn't measure the uppers with a loos guage.(They were that slack) We felt that pulling them on stopped the boat from breathing. We left them on the same hole for all wind ranges as they automatically loosened when you increased rig tension on the primaries when it was breezy.
Building a Swift Solo
First Australian Swift Solo
Sailing F28 Tri - family cruiser
BBSCFaithfull View Drop Down
Post Options Post Options   Quote BBSCFaithfull Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 07 at 8:19pm
Originally posted by redback
They are much flatter than my Laser4000 which has very similar speed.
Cough stewpot
They are flat because you dont have the extra leverage of a trapeze. So the sails need less powering up
Greatfully Sponsored By
www.allgoodfun.com
Int 14 GBR 1503!!
redback View Drop Down
Post Options Post Options   Quote redback Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 07 at 10:50pm
NickA View Drop Down
Post Options Post Options   Quote NickA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 07 at 10:38pm
Thought they were supposed to be really flat on the basis that the boat will always be going up (apparent) wind.
We talking Tasar flat, Ice yacht flat or just MUCH too flat here?
Javelin 558
Contender 2574
Post Options Post Options   Quote redback Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 07 at 10:02pm
We have a 59er in our club (Wilsonian).  The sails seem very flat.  The main is now much better since we have reduced the caps to 10 on a Loos gauge and the mast is now not so curved.  The jib however is extremely flat, the top batten straight and you have to come down the sail about a 1½m to see any sign of curve.  We have tried loads of luff tension.  Any ideas?  Or do any 59er sailors recognise this.  I'm trying to get a photo  from the owner but I hoping to beat the owner to a solution.
