questionnaire for a-level D.T |
Page <123> |
Author | |||
![]() ![]() ![]() ![]() Posted: 15 Nov 06 at 8:06pm |
Yep,. that might work - The problem would be even worse on Cats as the mast also rotates. |
craig-m ![]() Newbie ![]() ![]() Joined: 28 Oct 06 Location: United Kingdom Online Status: Offline Posts: 34 |
I'm doing GRAPHIC PRODUCTS at GCSE, and i had to do exactly that. I couldn't get to the sailing club to ask sailors, and nobody else knew what the product was! Still...teacher didn't know the dfference! |
RS300 406DERBYSHIRE YOUTH SAILING
Burton Sailing CLub Sailing: The only sport that's called off for nice weather |
i didnt
Also International 14, 1318 |
Kiteboy ![]() Newbie ![]() ![]() Joined: 03 Apr 06 Online Status: Offline Posts: 7 |
wow you guys have really boring tech projects! im only doing GCSE and im making a carbon fibre kiteboard
Laser Radial 185598 (transitional squad...oh yeah)
3 and 7 and 14m kitesurfing kites |
It would have to be a pretty tight bit of engineering not to suffer from slop as the boom moves quite a bit. How about using an electronic compass and seperating the display from the sensor - I think Nigel Buckley did this on his 470 in th 80's ... |
No doubt that's the design element of his project, but one obvious way of doing it is to have a mechanical linkage so that the compass housing turns on the boom exactly in synch with the boom turning on the gooseneck. That would only work for non-rotating masts though: with a rotating mast the linkage would have to be relative to the deck so it would be more complicated to rig but still possible. |
Adds ![]() Posting king ![]() Joined: 14 Jan 05 Online Status: Offline Posts: 126 |
I agree with Rick if the boom is going in and out how is it going to get the correct bearing, unless you spend £399 on a tacktick mast rotation sensor.
Cheers Dudes
lozza ![]() Far too distracted from work ![]() ![]() Joined: 23 Sep 04 Online Status: Offline Posts: 262 |
eliot, just pm'd you my response. |
Life's a reach, then you gybe
good luck with your work, again an example of someone who got a more interesting project than me (gooddam puppet show muttermutter ahh i see A level, that might explain it. Edited by mike ellis |
I fear you have a fundimental problem - if the compass is rotating it won't give you the heading of the boat in an accurate fashion ... Rick |
Page <123> |
