Thoughts on the Laser Vago |
Page <1234> |
![]() ![]() ![]() ![]() Posted: 13 Nov 06 at 11:08am |
As new boats go, the Vago is pretty good value. Obviously there isn't a great second-hand market at the moment. We have one Vago at the club that races against other two handed boats - RS200, Laser 2000 and Fireball. And it seems to do OK (it has won on Hcap the past two weeks). Marketing has been a little suspect and Laser need to work on this because I am trying hard to think of a boat that they have produced since the L2 that has succeeded. L3000 - discontinued. L5000 - not a 49er. Vortex - sold a few more than the EPS. You get the drift. The only recentish boat that has a good following is the L4000 and Laser have suggested the Vago in XD mode is almost as fast as a 4000. Chinny-reckon! I think the Vago sits most comfortably alongside the Vareo. If you have a regular crew then get something else like a 4000 or 29er. If you are going to be sailing half the time solo then the Vago is worth a look. |
i found them a biut flexiable and go bow high alot. it is a good training boat but i cant see many people wanting to race them go for a buzz or a 29er |
TWO FRANK-Hunter Impala
PaulUK ![]() Newbie ![]() Joined: 22 Jan 05 Online Status: Offline Posts: 14 |
Hi Bought my Vago about 10 months ago now and find it to be great fun. Sails well with one or two. Dont race, so dont really care what that lot think! Sailed an Enterprise before that but wanted something with a bit more versatility.
Have fun
Paul Sail No. 303 |
PaulUK
CurlyBen ![]() Really should get out more ![]() Joined: 17 Aug 05 Location: Southampton Online Status: Offline Posts: 539 |
Not sure I'd really recommend the Vago for predominantly single handed sailing, certainly with any breeze and the XD rig it can be difficult/impossible to bear away out of a tack. I've had to gybe it instead on occasions. It's also a pretty heavy boat on the shore, though it's not too bad on the water. The plastic can be fairly slippery when it's wet, which can be an issue for getting back onto the board when capsized. Having said that it's fun downwind in a blow with a crew - as long as the pintle bolts hold!
RS800 GBR848
Weston SC |
On the Standard rig it easily sailed singlehanded in a breeze and can of course be reefed. I have sailed singlehanded with the XD rig and the kite up in lighter airs! It is probably better with two (both onshore and in the water) but is quite manageble with one. Paul |
PaulUK
I've only properly single handed the Vago once, and I was using the jib and kite then anyway. However, when sailing out with relatively rookie crews I often didn't use the jib and got some scared looks when I had to head straight at a jetty before a gybe! I think that was with the XD rig, and admittedly the foils weren't fully down - not enough water! Still, I can't say I'd recommend the Vago, though I can't think of a better alternative that wants to be both a proper single hander and a proper double hander. Just not an idea that I think really works!
RS800 GBR848
Weston SC |
Pesmo ![]() Newbie ![]() Joined: 10 Oct 05 Location: United Kingdom Online Status: Offline Posts: 25 |
Sailed the Vago a couple of times as a single hander with just the main. Even though I am 110kg and have sailed all sorts of boats, I never quite felt comfortable. It felt to me like one of those boats that goes from being a placid nice easy sail, to a very difficult boat indeed with a very small increase in wind. That may of course have been what the designers intended. All the other folks who took it out the week I was there had stronger winds than me and even though were double handed spent significant time swimming or completely inverted. I would need to sail it some more to give it any seal of approval.
yellowhammer ![]() Far too distracted from work ![]() Joined: 08 May 05 Location: United Kingdom Online Status: Offline Posts: 270 |
check this out, from the Vago forum (pump up the volume) http://video.google.co.uk/videoplay?docid=-20132458682747327 10 you have to admit the Italians (?) do it in style! (spot the double capsize) |
Laser 3000 @ Leigh & Lowton SC
www.3000class.org.uk |
it does show how heavy and flexible the boat... There is a good breeze blowing and its struggling to push enough water aside to get upto any kinda speed
I see its bow high problem. |
-[Franko]-
Page <1234> |
