Room for an obstruction |
Page <1234> |
| Author | ||||
Nacnud_smada
Topic: Room for an obstructionPosted: 24 Sep 20 at 10:30am |
A hailed boat shall respond either by tacking as soon as
possible, or by immediately replying ‘You tack’ and then giving the hailing boat room to tack and avoid her. Does this part not get rid of the While tacking rule? |
Nacnud_smada
Posted: 24 Sep 20 at 10:31am |
Brass
Posted: 24 Sep 20 at 10:34am |
Nothing 'switches off' the Part 2 Section A Right of Way rules (rules 10 to 13). The closest you can get is that a boat that fails to keep clear may be exonerated if she is sailing within that room or mark-room to which she is entitled (rule 21), or is compelled to not keep clear by another boat breaking a rule (rule 64.1(a)). So a good place to start in solving a rules problem, is to identify who has right of way, and whether a right of way rule has been broken. Then you can look at whether other rules have been broken. Then consider exoneration. And not one of the rules mentions 'room and opportunity'. |
Nacnud_smada
Posted: 24 Sep 20 at 10:40am |
Ahhh englighting
Thank you |
Brass
Posted: 24 Sep 20 at 10:48am |
So
Which boats broke what rules? |
Nacnud_smada
Dunno yet.
Need to do what you suggest.. When I'm at a computer 😂😂🖥️🖥️💻 |
Nacnud_smada
Posted: 24 Sep 20 at 11:39am |
So two boat on same tack
Rules 11, In play.. not broke Rules 20.. Kicks in.. 20.1 there was a hail. not broke 20.2 - was there a response... nothing heard.. you tack... or tacking.... Broke - laser wrong. collision happened while tacking... so rule 13.. had so Solo completed tack at point of collision? (unsure) if not then solo wrong. if yes, Was laser tacking... if yes. laser in wrong as did not keep clear? it both had complete tack.. who was to leeward then rule 11 back into play.... What do you think? |
Brass
Posted: 24 Sep 20 at 12:11pm |
So
Solo WAS entitled to hail, hailed, gave the Laser time to respond: Solo complied with rule 20. Laser did not respond by either tacking or hailing 'you tack': Laser broke rule 20.2(c). OP did not mention Laser tacking, so lets assume that Laser did not tack, remained on Starboard. There was contact either just before or just after the Solo reached her close hauled course on Port: Solo broke either rule 13 or rule 10. Was the Laser entitled to room? if so under what rule? Was the Solo entitled to room? if so under what rule? |
davidyacht
Posted: 24 Sep 20 at 12:15pm |
Similar situation the other day ... two boats sailing to windward on starboard with a couple of boat lengths separation, leeward calls "room" as a precursor to tacking then completes tack onto port at which point starboard tack boat calls him back onto port.
If the windward boat had responded by saying "you tack" does the windward boat give away the right to call the leeward boat back onto starboard? How close does a hailed boat have to be to be obligated to respond? Does a boat that does not need to respond have to either hail or manoeuvre even if the hail is opportunistic and unnecessary?
Happily living in the past
Nacnud_smada
Posted: 24 Sep 20 at 12:48pm |
Sorry, missed that part..
Solo Hailed... no reply from laser... tacked.. laser tacked collision... I dont see any entitlement to room? other than laser has to reply and then act... be that sail on or tack?
Edited by Nacnud_smada - 24 Sep 20 at 12:49pm |
Page <1234> |
