New Posts New Posts RSS Feed: 29er Jib dimensions
29er Jib dimensions
Jack Sparrow View Drop Down
Post Options Post Options   Quote Jack Sparrow Quote  Post ReplyReply Direct Link To This Post Topic: 29er Jib dimensions
    Posted: 13 Apr 18 at 2:46pm
Originally posted by mozzy
Radius doesn't look very tight. I doubt you'l get kinking at the holes. Certainly looks a wider radius than the 29er track, and I never had a problem screwing that down from straight.
I'd just work from one side to the other, drilling and screwing down as you go.
+1
Or just mark the track holes on Jims bit of ply. Clamp it to the track bed which should transfer the eventual position of the track holes when bent? Then drill holes. Bolt down track. Or have I just repeated what you said Jim?
Post Options Post Options   Quote Jack Sparrow Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 18 at 2:47pm
Oh BTW, didn't fancy a Banshee then. LOL ;-)
Granite View Drop Down
Post Options Post Options   Quote Granite Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 18 at 9:29pm
Agree that a bendy bit of ply would work to transfer the hole positions. Just need to decide what track to get.
I fancied a new build and liked the look of the Everest 1, the build method was also interesting and helped make a quick build.
Post Options Post Options   Quote Jack Sparrow Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 18 at 9:44am
Only kidding... I think Clive Everest's UKCherub should have been built more by now. A great bit of production design. Good luck with it, it looks great from what I can see.
