Fireball Spinnaker Launch system |
Page <123> |
![]() ![]() ![]() ![]() Posted: 15 Feb 17 at 8:17am |
It could be a very late registration of a boat built from a kit. It looks like a single skin hull to me (not foam sandwich), though its hard to tell from the photos. The main builders around that time of composite hulls were Winder - which i dont think yours is - and Severn Sailboats which is possible but it doesn't look like a Severn deck, the cleat blocks are too angular though they could have been fitted later. The coaming on the inside at the back could be a giveaway but you cant really see in the photos.
Does it have a builders ticket on it anywhere? If you apply for a measurment certificate that should list the builder and you will not need to get the boat remeasured. The association badges correspond to the sort of time a 14xxx number would have been issued. There one 40 year old Plycraft hull with a 150xx number that sat in a barn unregistered and unfinished for 35 years! Looking at the photo full size the boat looks well kitted out with decent fittings and the boat looks to be solidly built. I just find it strange that they didn't cut the deck out for the bags when it was built after doing such a good job of the rest. Having totally hijacked your thread (Though a mystery boat is always interesting!) i'll say you're doing the right thing cutting the holes for bags. Round the edge off and give it a good resin coating as the halyard and sheets will wear the varnish and eventually the wood away quite quickly.
Edited by Paramedic - 15 Feb 17 at 8:28am |
The thwart, mainsheet 'tower' and inwhales treatment look very much like my Severn did, but they used almost exclusively Sapele for decks, so I wonder if it was supplied with the hull and interior woodwork but no deck? The UKFA Membership Sec - Ian Castle - can be contacted thru the new website and will hold a copy of the certificate, I think.
Are there two holes in the fwd bulkhead, or any evidence of a chute being removed? If so, it could be a redeck...
Nick
D-Zero 316 |
Josh14441 ![]() Newbie ![]() Joined: 13 Feb 17 Online Status: Offline Posts: 11 |
Wow, Thanks everyone for helping me find out more about this boat.
There is only 1 hole in the bulkhead but it does look to be in the same place that a chute would be the only thing I can think of is maybe when the previous owner had it re-decked he may not have used the spinnaker and just used the boat for casual sailing I will post some more pictures later on today.
Edited by Josh14441 - 15 Feb 17 at 9:37am |
MYC is its old club
Edited by Josh14441 - 15 Feb 17 at 9:21am |
When it was (re-)decked, they clearly equipped it with cleat raisers for the guys, so I guess they just used bags under the deck?
bagged kite FBs would have, as you say, 'scooped' foredeck or holes in the deck with the bags beneath. i premuse the reference to 'chuck it' launch would be exactly that ... even though youcan do a 'pick up and chuck' launch from through deck bags , esp if the sail is in the windward bag ...
I think that that is a Severn composite that has had the deck ply replaced. The hatch at the front looks like its always been a hatch, chutes on fireballs tend to be fitted to starboard and the bow tank would have had an inspection hatch from new - therefore the hatch to starboard has always been a hatch.
Thanks, everyone I have emailed the Membership Sec asking about the certificate and will cut holes for bags this weekend. And considering these photos were taken 2 weeks ago and the progress I have made it should be done in 2 - 3 weeks.
Thanks Josh
Does anyone know what size the spinnaker bag hole is as I can't find any measurements online and placement Ie distance from the edge of the cockpit and the edge of the deck
Thanks
i'd buy some standard bags and make the holes to suit.
Page <123> |
