Deck Scribling |
Page <12 |
iiiiticki
Joined: 06 Mar 16 Location: Derbyshire Online Status: Offline Posts: 206 |
Topic: Deck ScriblingPosted: 21 Jun 16 at 9:08am |
On my Lightning there is a hatch cover on the bulwark. I write the course on a strip of masking tape....not that it matters because there are always plenty of boats to follow.........
maxibuddah
Posted: 21 Jun 16 at 8:20pm |
I always found that was the best method
ColPrice2002
Posted: 21 Jun 16 at 10:22pm |
For our home club, a map of the lake showing the fixed marks; laminated in plastic with a small golf marker pen (because it can be fitted with a lanyard).
For the Solo, strip of electrical tape (white) plus marker pen (keep in halyard bag). I tried the non-sticky notepads, I found 2 problems. The wipe off was far too easy, and they will also float off if they get wet (spray, capsize ) |
patj
Joined: 16 Jul 04 Location: Wiltshire Online Status: Offline Posts: 643 |
Posted: 22 Jun 16 at 1:14pm |
We left a laminated map stuck to the side tank for a season and found on removal that it was damaging the gelcoat underneath - bubbling that looked like osmosis. Now we remove anything straight after an event.
zippyRN
Joined: 14 Sep 06 Online Status: Offline Posts: 437 |
Posted: 23 Jun 16 at 10:19am |
bit of a 'no faecal matter , sherlock ' moment surely ...
iGRF
Posted: 23 Jun 16 at 12:40pm |
Masking tape stick it to the sleeve of your dry suit, round the mark first, notice it's blown away, have no idea where to go next.
Dry suits need those marker things the pilots have on their upper thighs. Whatever you write on the boat you can't see it, it's on the other tack, there's water on your glasses.. |
iiiiticki
Posted: 23 Jun 16 at 9:31pm |
A girl I know always wears hikers that expose her lower leg. She writes the course there in biro.
craiggo
Posted: 23 Jun 16 at 11:16pm |
Those market things that pilots have on their thighs are just pockets with hole in the front. A white piece of card or a template can be put in with a sheet of clear plastic over the top. You then write on the clear plastic with a non-permanent marker. Normal notes taken are things like qnh and qfe (pressure settings for determining altitude).
OK 2129
RS200 411 |
realnutter
Joined: 17 Nov 15 Location: Reading, UK Online Status: Offline Posts: 129 |
Posted: 23 Jun 16 at 11:37pm |
Altitude is only an issue for foiling Moths....
Page <12 |
