Duct/duck tape remover? |
Page <12 |
![]() ![]() ![]() ![]() Posted: 08 Oct 05 at 9:50pm |
Petrol, it desolves most contact type adhesives. Be careful if you acetone its likely to make your glassfibre gel coat a bit soft.
kasey3000 ![]() Far too distracted from work ![]() ![]() Joined: 06 Apr 04 Location: United Kingdom Online Status: Offline Posts: 401 |
thye hav pro grip on but thats comin off as it's peelin neway.... lemon juice could b good! |
49er 908
CurlyBen ![]() Really should get out more ![]() Joined: 17 Aug 05 Location: Southampton Online Status: Offline Posts: 539 |
Are the wings coated at all? I wouldn't try brasso on anything other
than the bare material (I've used it on plastic and stuff as well, but
it can scratch).. thinking about it I'm not sure brasso would work
well, it's a polish, not a solvent. Seem to recall lemon juice being
good actually..
i migt try brasso on the wings...as it polishes trophies fine without burnin or tarnishin but i think it would be too strong for the hull.... i'll giv the eucalyptus oil a go....sounds a good idea |
49er 908
Wouldn't try Brasso, think it would be too abrasive. Acetone or white
spirit might work, but I'm not going to recommend either because I'm
not sure whether they'll damage damage the hull. I'd go with the
eucalyptu oil first, doesn't sounds like it'll damage anything, which
is the big thing to check for! The other thing is to check it on a
small, relatively unimportant bit first if anything does go wrong..
Yes....I have now learnt not to use duct tape on boats.....trouble was thats how the boat came! eucalyptus oil!....sounds intrestin but should be a worth a go!...am so desperate to get it off cos i hate it!!! this might be really bad and not the thing at all!...but might brasso work? |
49er 908
Haggis ![]() Posting king ![]() ![]() Joined: 23 Mar 04 Online Status: Offline Posts: 180 |
Remeber T Cut is a scouring agent and will scratch your boat, eventually if used on the hull For a good remedy eucalyptus oil is a winner, what the bus agencies used in the 50's to get tar of their buses from newly laid roads. A little dab of it goes a long way and it is natural. Get it from most herbal/aromatherapy places. As for Duct tape, Golden Rule - never use outside where the UV gets it, at all! And if used should only be for emergancy use, eg repairing a whole while on the water. Only tape that should be used is Dacron or PVC, and even then after a long exposure period they will leave a nice sticky residue, but never as bad a duck tape. For shallow scratches a glass fibre rubbing compound is best. You won't see many boat builders with T-Cut on their shelves. Edited by Haggis |
I haven't used T-cut b4....i'll giv it a go tho! thanx Stuart!!!
49er 908
T cut always works well for me and it'll even remove shallow scratches! Hows that 4 u? Edited by stuarthop |
Is there a cleaner that will remove that horrible sticky residue left by duct/duck tape? It has to be safe to use on metal wings(boat is a laser4k) and the hull itself???...i.e. i dont want it to tarnish the bars and melt the hull the guy who I bought the boat off seemed to like using duct tape on everything and i don't like to use 2 much of the stuff cos of the residue...so am now desperately tryin to get it off any help much appreciated! kasey. |
49er 908
Page <12 |
