New Posts New Posts RSS Feed: Square tops
Square tops
 Post Reply Post Reply Page  <1 910111213>
CT249 View Drop Down
Post Options Post Options   Quote CT249 Quote  Post ReplyReply Direct Link To This Post Topic: Square tops
    Posted: 08 Jun 22 at 9:22am
Originally posted by ChrisI
Originally posted by Mozzy
I actually think square tops are easier to get to work with a solid mast, like those used by cats rather than a whippy carbon mast seen in some other classes (skiffs). So I think they can be made to work with a pretty solid mast which is designed with very little compliance. Cats go for rotating masts which are very stiff and need less in the way of stays to keep them upright. Then use sheet tension, Cunningham and battens to control the stability of sail (response to gusts).
But doesn't the 'gust response' you get in a cat with a stiff aluminium mast come from the fact there is no kicker tensioning the leach i.e. the gust hits and the mainsail clew rises slightly (and comes inboard slightly) opening the top of the sail...?
Nope, or not from my experience owning and sailing a couple of them. The cat don't need as much gust response as their higher upwind speed means that a gust is a lower percentage of apparent windspeed. They also (as far as I can recall) use flatter sails than skiff types, so it needs actual less twist and mast bend to create a similar depowering effect.
I've never seen my F16 or F18 clew rise or come in to windward, personally. The mainsheet loads are way too high. We took the mainsheet off our old 20' cat and stuck it on the 36' 5 ton offshore mono we have, and it's easier to work on that than it was on the cat!
The proof may come in A Class cats. They have had extremely light carbon wingmasts, rather than stiff alloy rigs, for eons. Despite the fact that they could probably design in as much bend as they want (ie by shifting from carbon to 'glass etc) they have extremely straight masts - so straight that they don't use halyards at all but just push the sail straight up the mast from the bottom because there is basically no luff curve to create resistance.  But (AFAIK) the mainsail chord is so flat that the minimal amount of mast bend created by downhaul pressure is enough to completely flatten the sail when needed. Mono sails are still deeper (AFAIK) so have more draft to be taken out so need more mast bend.
This is just my belief and there are many people who know much more; I'll grab one of them when our season starts again.
Edited by CT249 - 08 Jun 22 at 9:42am
Post Options Post Options   Quote CT249 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 22 at 9:17am
[/QUOTE]
Square tops are in a sense just a modern interpretation of the traditional gaff rig.
But is it only carbon masts that they work with, that can flex and produce the desired 'gust-response'.... or can they work with aluminium/much stiffer spars?
Or could batten technology ensure that they do? (spring loaded battens!)......
[/QUOTE]
With respect;
I"ve spent a lot of time researching design history, and there seems to be little evidence that squaretops and gaffs have much to do with each other at all.
The traditional gaff rigs almost never used gust response in anything like the way we do, and that comes from a LOT of reading of books and articles from the 1800s and early 1900s.
The gaff's advantages were due to low centre of effort, fewer problems in keeping the stick aloft and things like that. After reading many hundreds of pages (my mag collection dates back to 1894) I can find no information that indicates that gust response was seen to be better with gaffs than with contemporary bermudans.
The gaff rigs were almost always low aspect, whereas squaretops tend to be fairly high in aspect ratio. The gaffs normally had too much twist, way more depth than we use, and were sailed at wider angles of attack upwind and downwind.
In cats like the Taipan 4.9, which has a very big and stiff wingmast even for a cat, the former large roach gave way to a squaretop over a decade ago, and the class opinion was that the gust response was very much better. To give an idea of the stiffness of the 4.9 mast, Glenn Ashby (who was a champ in them before he was famous) told me that the mainsheet load on the 96kg 16' Taipan 4.9 was higher than that of the vastly larger Tornado - and yet the very flat squaretop on the 4.9 gives good gust response. You don't need much movement when the head is already very, very flat.
Incidentally the Taipan's co-designer Greg Goodall is credited by many (like sailmaker Ben Hall in an old article in US mag Sailing World) with introducing the true squaretop in an A Class that his brother used to win the worlds in back in the '80s. Greg followed on by also winning two world titles in the class, but if I recall correctly he reckons the increase in squaretop area is (like so many things) largely down to improved materials that allow sailmakers to make sails that don't distort and therefore suffer from leaches that either blow open or slam shut. I haven't seen him in years so this is just from memory.
Edited by CT249 - 08 Jun 22 at 9:51am
eric_c View Drop Down
Post Options Post Options   Quote eric_c Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 22 at 9:12am
The H2 has a PN of 1034?
The Phantom, with almost no roach at all, 1004.
Blaze with a big round roach, 1033.
Dzero 1029
It's not looking like sailing's answer to nitrous oxide is it?
H2 View Drop Down
Post Options Post Options   Quote H2 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 22 at 8:31am
I always understood square tops were a development class thing to maximise sail area with a constraint on spar length in the class rules
If a new one design class has been developed with one, then it probably has more to do with aesthetics and commercialisation than good sail design
More than happy to be corrected if this isn’t true!!
The H2 was a new class designed with a square top from the outset. The rig was designed by Jim Hunt from HD sails and not a man I would use the words "aesthetics or commercialisation" in connection! Of course it is possible that you are a respected founder of a sail loft and multiple world champion TT - I know I am not - but I reckon Jim designed a rig that he felt would work well rather than look pretty.
H2 #115 (sold)
H2 145
OK 2082
The Q View Drop Down
Post Options Post Options   Quote The Q Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 22 at 6:28am
I think on the Norfolk Punt it's a case of getting sail area up high as in many areas of the broads we are badly affected by trees.
Many of the Broads cruisers have jackyard tops'ls, some now have them permanently fitted, so their only reefing is at the bottom..
The Merlin has a Size limit (10sqm?)  so for them by moving as much area as they can up high, they should get stronger clearer winds.
Currently on my one off, I'm using an old Kestrel Sail (and mast), that has a long top batten, a sort of semi square top. Even with just that it sometimes decides to stay curved the wrong way, needing a sharp tug on the main to "pop" it.
When  the new sail made I was thinking of going square top, but my one off is very round bilged with little form stability and also I need to move the sail area aft a bit. So now my current thinking is she needs a longer boom and just go for a conventional top.. But there's another couple months trials needed before a final decision needs to be made.
Still sailing in circles
Oatsandbeans View Drop Down
Post Options Post Options   Quote Oatsandbeans Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 22 at 5:06am
I agree-the reason that the mid leach has such an effect on pointing is that it effects the upwash on the air hitting the jib luff. Having a mid leach close to the centre line makes the wind in front of the jib bend -in effect giving you a lift. If you ease the main and the mid leach moves away from the centre line you lose this.
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 22 at 9:47pm
Yes, one of the key things is the mid leech. If the mid leech doesn't stand up then the boat won't point. So in my dream world the top of the sail would flop off completely and the bottom 2/3 of the sail wouldn't move an inch. AFAIK that's pretty much unachievable, but with all full battens and stable cloth it goes a substantial way towards.
Overrotating rigs march to an utterly different drummer because the mast tip bends up to windward...
ohFFsake View Drop Down
Post Options Post Options   Quote ohFFsake Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 22 at 9:33pm
If you watch the (truly excellent) 18 footers tv coverage on youtube, and pick a windy race you'll see plenty of examples of what they jokingly refer to as "flappage".
This is the top section of the fully battened mainsail completely inverting in the gusts, so the battens more or less pop the wrong way.
This is probably the clearest demonstration you will ever see of automatic gust response, and explains at a glance the whole reasoning behind square top sails.  In the gusts the bottom half of the sail is providing drive with leach tension giving good pointing, whilst the top of the sail is completely feathered for minimal drag and heeling moment.
Edited by ohFFsake - 07 Jun 22 at 9:36pm
Post Options Post Options   Quote eric_c Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 22 at 8:17pm
Re H2
Yes that's helpful.
Maybe that's general to sails with a lot of roach rather than being specific to flat-head, I've seen a few sails which are hard to make sense of when the wind gets too light.
Some boats you can leave the kicker off  in light air because the sheet gives the right blend of pulling the boom across and leach tension.
A lot of factors than can't be isolated from one another, too many variables.
Edited by eric_c - 07 Jun 22 at 8:22pm
turnturtle View Drop Down
Post Options Post Options   Quote turnturtle Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 22 at 7:59pm
Edited by turnturtle - 07 Jun 22 at 8:00pm
