Jib sheets |
Page 123> |
headfry ![]() Far too distracted from work ![]() ![]() Joined: 15 Jul 04 Location: United Kingdom Online Status: Offline Posts: 359 |
![]() ![]() ![]() ![]() Posted: 21 Mar 05 at 2:27pm |
Can I have your views on this subject please............
Are continuous jib sheets a better idea than each side ( as it were ) - on an RS400 |
I tend to use continuous sheets on the grounds that I find that an end is about 4 times more likley to get tangled on/in something. |
5420 ![]() Really should get out more ![]() ![]() Joined: 16 Mar 05 Location: United Kingdom Online Status: Offline Posts: 622 |
If you dont tiy them togever they can get sucked in by your selfe balers
moomin ![]() Groupie ![]() Joined: 19 Jan 05 Online Status: Offline Posts: 60 |
I would say continuous sheets are a must on the 400 loose ends inside the boat will get caught and tangled and it also means the helm can get hold of them to adjust if the crew is having to concentrate on the kite. I tie both end to the jib so there are no loose ends or knots inside the boat. Also not going to come undone as they might if you just tie the two ends together.
Moomin
KnightMare ![]() Really should get out more ![]() Joined: 08 Feb 05 Location: United Kingdom Online Status: Offline Posts: 1682 |
Also I tend to hike holding onto my sheets so that I have somehting to pull back on and if worst comes to worst you can uncleat everything. If you havce continuous sheets it is easy to get hold of the 'leeward' sheet as it is attached to the end of the one you have next to you.
I agree continous sheets are best. Also good in a 400 is for the crew to tack with your back to the mast. That way it keeps your weight forward and you don't have to duck so low since you bum fits nicely into the triangle formed by the kicker. The jib sheets fall nicely to hand also. I know Headfry is probably not that interested in racing but if you are you still have to be able to tack facing forward because at the windward mark it is still required. When tacking close to the mark you have to be able to tack, sit out hard (and slightly more aft than normal to keep the bow out) for the bear away and then get the pole out and on completion of the bear away raise the kite. To do that and not get completely dizzy requires a forward facing tack. Incidentally another racing tip is don't sit on the thwart - I know its comfortable there but its too far aft unless it blowing a bit - in which case you should be sitting out! |
Mike278 ![]() Far too distracted from work ![]() ![]() Joined: 09 Mar 05 Location: United Kingdom Online Status: Offline Posts: 256 |
though continuous jib sheets have advantages, it also comes down to personal preferance (i prefer seperate jib sheets).
Never, under any circumstances, take a sleeping pill and a laxative on the same night.
Thanks a million (again) for the invalueable help. Think we will go for cont. jib sheets.
Redback, yes we will have a go at racing, but we don't want to mess with the good guys and spoil their racing ![]() ![]() ![]() Hope to have a go at rigging her over Easter (should be fun), and if weather is calm, then it's out on the water for us! ![]() ![]() ![]() Wishing you all "happy sailing over the Easter hols." |
Talking as someone who always races and almost never cruises (you couldn't in a 4000 anyway). I'm always keen to encourage people to race and very tolerant of their mistakes. Cruising is OK but there is nothing like the pressure of competition to drive yourself to higher levels of achievement, and frankly achievement is what gives the greatest satisfaction. So Headfry, please race, you've bought a beautiful racing machine, I'm sure other racers will be helpful and tolerant and you will enjoy the boat so much more. |
yeah, I would say race. But it is upto personal choice. Also I see you have chosen cont. jib sheets.
Page 123> |
