My ankle! |
![]() ![]() ![]() ![]() Posted: 30 Nov 08 at 3:12pm |
Cheers for the top tips. I think its strengthening and getting stbility back. First stop Monday will be seeing a sports therapist then off to buy one of those retro space hoppers! Thanks for your help.
MJ is right. A balance ball or wobble board is what you need. You can get one easily on the 'net, usually with a set of suggested exercises. It will strengthen the ankle joint as well as the lower leg which will help the ankle too.
oh and then sell the thing on ebay when you're done! Edited by winging it |
See a sports physio (some "health clubs" like John Lloyds or Virgin Leisure have clinics on site). About £30 a session and worth every penny. You might even get it on the NHS if you're very very patient (and/or totally crippled).
It seems like you're paying a lot for something you can usually do at home or in the gym (some massage and exersise) but it gets you focused on the right things instead of bumbling along steadily making things worse. I got joint fatigue in an ankle in my early 20s from ill fitting ski boots. Sufferred repeated and unpredictable sprained ankles for several years till a physio showed me how to put it right. |
Javelin 558
Contender 2574 |
Status ![]() Posting king ![]() Joined: 10 Nov 08 Location: United Kingdom Online Status: Offline Posts: 114 |
A good sport injury specialist could be the best thing for you. There is a reason all those wealthy football clubs send their players to them when they have injuries. I realise time is a great healer but ankles are difficult as you can't avoid using them during the day. A little specialist help could reduce the recovery time.
Ankle support is always a good idea if you are suffering from weakness.
I have a similar thing with one of mine where it randomly just collapse or twists. No pattern to it and no warning signs. I have found getting down the gym and hitting the crosstrainer has helped (lots of movement of the ankel joint and no impact). That followed by doing the required stretches when finished has help a huge amount. Just need to work on core stability now! |
An ankle support of some kind to prevent another twist in the meantime.
Ex-Finn GBR533 "Pie Hard"
/\ they take me back, you had to have the ball pumped up otherwise you hit the floor!!
I broke my ankle about a decade ago. While it takes an age for the break to heal properly it is the muscles that really suffer. One of the best things I found to use is a balance ball like this: And physio - lots of physio. |
hi i broke my ankle a couple of years back and i was out of the boat for six months even when i got back in the boat i still did not feel quite right but after lots of physio on it it was alot better. the exercise which worked best for me was running on a trampoline which seemed to free up the joint i still struggle some times going upwind in the vareo so i just hike with one leg taking most of the effort. as richard says above go and physio on it they do a great job and it works. |
Other half badly sprained her ankle this time last year (well did it 31st Oct!!)
Although it took her a while to get walking again, it took longer to repair the muscle. It did put her sailing back. She did have physio, something that if you haven't had, you should go and get cos she was given loads of excercises, if you are interested, pm me rather than me listing it all here!! |
