Speed Solo |
Page 123> |
![]() ![]() ![]() ![]() Posted: 22 Feb 05 at 4:12pm |
This looks like quite an interesting boat! It's sailed in america, looks beautiful. Apparantly it's got 36sp metres of sail downwind, tasty! |
I saw an article about this, it has a really clever system to sheet the jib with the main. You set the relative sheeting angle of the jib to the main and then as you ease and pull the main it sheets the jib too. Wooden hull but light, looks fun!
FLAT IS FAST!
Shifts Happen |
As i probably am correct me if im wrong ! |
-[Franko]-
oooooooops didn't see the post before i wrote that........that explain's |
-[Franko]-
What about the Int Canoes? They have had 2 then 3 sails for ages. |
Bonnie Lass Contender 1764
Oh yeah sorry my mistake |
-[Franko]-
That boat looks pretty cool what size py do we recon its sailing to?
hydrographer20 ![]() Really should get out more ![]() ![]() Joined: 11 Feb 05 Location: United Kingdom Online Status: Offline Posts: 867 |
looks like a good high performance boat, wouldnt mind having a go!
byte me!- GBR 814
but it's heavy!!! designed for home construction from cedar and glass sheathing. Hull is cross between contender, 505 and suppposedly 49er also. Rig is cut down 49er. However the righting moment ( this determines how much power you can actually use ) is quite low - one crew on wire on a narrow hull no wings. |
Which explains the small mainsail on a short mast.
Page 123> |
