New Posts New Posts RSS Feed: Wooden Ramps at  Sea Clubs
Guest View Drop Down
Post Options Post Options   Quote Guest Quote  Post ReplyReply Direct Link To This Post Topic: Wooden Ramps at Sea Clubs
    Posted: 18 Mar 08 at 3:18pm
Anyone on here a member of a club that has a wooden ramp set on wooden piles at a sea club?
At Whitstable we are having a few problems with the ramp and would like to learn from what others have done to maintain their ramps ...
Post Options Post Options   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 08 at 3:48pm
Well we buried ours for 7 or 8 years, the storm has just exposed it the
weekend gone as can be seen below.
I'm surprised you've got problems with your slip, we were very envious of it,
it was built around the same time they buried ours in shingle, but then ours
was a recycled version of one built back in the seventies from discarded
railway sleepers and track.
Edited by G.R.F
radixon View Drop Down
Post Options Post Options   Quote radixon Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 08 at 4:14pm
not sea but inland they replaced the ramp at the centre I work at. Let me know if you want pictures.
29er310 View Drop Down
Post Options Post Options   Quote 29er310 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 08 at 4:21pm
At my sailing club (itchenor), they have to pressure hose the slip nearly daily in the summer at low tide to get rid of any weed which has decided to set up shelter on it, otherwise it becomes very slippery. The whole of the sailing club is on a decking which is on piles sunk into the mud the planks have to periodically replaced otherwise they become a bit dangerous.
International 14 GBR1485
29er 310 for sale
Laser 138462 for sale
Optimist 4626 For sale
Villan View Drop Down
Post Options Post Options   Quote Villan Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 08 at 4:42pm
Ours (Inland) is concrete, and then wood.
I dont theres anything done to maintain it, other than periodically replacing the dry-slope ski matting on it. ( When parts get pulled up by trailers or whatever. )
TandyUK Servers
Post Options Post Options   Quote radixon Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 08 at 5:39pm
Which rips your wetsuit or skin!!
tmoore View Drop Down
Post Options Post Options   Quote tmoore Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 08 at 7:07pm
our local council decided to put anti-foul on llandudno slipway and now its lethal. the first time we used it after it was done the tractor (big farm one not the little lawn mower style) slid and water came as high as the cockpit. luckily it didnt stall and was hastily reversed but suffered some engine damage due to the water.
as for maintenance, a pressure washer would be good. better still would be strategically placed railway grip (along tyre tracks) to allow grip but leave gaps to put boats should the need arise.
Landlocked in Africa
RS300 - 410
Firefly F517 - Nutshell
clip View Drop Down
Post Options Post Options   Quote clip Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 08 at 10:02pm
Took a walk past Herne Bay Sailing club the other week, they have a metal base with wood ontop, think they remove the wood over winter to keep it in good condition
Matt Jackson View Drop Down
Post Options Post Options   Quote Matt Jackson Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 08 at 10:52pm
Yep, the base is made of railway track bolted together and the slats are 5 heafty bits of Elm nailed to end rails. The slats are lifted over the winter or they go missing in the staorms. Of course you have to spend a day at either end of the season lifting/laying but at least they stay in fairly good condition. As there is smallish gaps between each slat you always have something to brace your foot against pulling the boat up. They wood used to get treated once a month with chlorine to kill the weed (not sure you could do that these days) - my Dad used to be known as Captain Chloros as he did it mostly.
Laser 203001, Harrier (H+) 36
Steve H View Drop Down
Post Options Post Options   Quote Steve H Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 08 at 8:18am
We're the other side of the Estuary at Leigh and we have have wooden storage racks and ramps. The ramps are made up of old railway tracks, sleepers and double dipped planks. WE have a couple of work parties every year to replace old planks and make repairs to the ramps. Main problem this year was a few steel clamps failed due to corrosion.
