Rig tuning |
| Author | ||
simski81
Topic: Rig tuningPosted: 26 Feb 08 at 1:52pm |
Hi I am currently setting up a new rig. To achieve the same tension as the old rig I am having to put the shroud pins a lot lower. I am yet to check the rake but have noticed that there seems to be more spreader deflection on this mast compared to the old one. So my question is this: does deflecting the spreaders decrease the distortion in the shrouds (explaining why the shrouds/forestay seem longer) or have I just got longer wires on this mast? Obviously measuring the rake would go some way to explaining this but the mast is dropped and ready to tow so I won't be doing that until the weekend. Thanks |
NeilP
Joined: 23 Nov 04 Location: United Kingdom Online Status: Offline Posts: 271 |
Posted: 26 Feb 08 at 3:12pm |
Too many variables to be able to help much, I'm afraid. Spreader length, deflection and height could all be different, as could hounds position and forestay length. I'd certainly start with setting the rake and spreader settings the same as the old rig, then go sailing. It would be unusual to be able to just change it all over and go. Neil |
No FD? No Comment!
Posted: 26 Feb 08 at 3:49pm |
They could all be true... Longer spreaders and more deflection would tend to make the shrouds seem shorter though.
Chas 505
Joined: 19 Dec 06 Location: United Kingdom Online Status: Offline Posts: 119 |
Posted: 26 Feb 08 at 6:29pm |
7 - finally recheck the rake, tensions and prebend again to see what has just slipped out of position (and mark everything...!!) hope this helps.
Life is too short.
Work Hard; Play Hard; Sail a 505 |
