Tell tails - where to attach |
Page 123> |
Pesmo ![]() Newbie ![]() Joined: 10 Oct 05 Location: United Kingdom Online Status: Offline Posts: 25 |
![]() ![]() ![]() ![]() Posted: 24 Sep 07 at 8:21pm |
Okay, Perhaps a bit of a numpty question, but looking round the boats at my club they seem to be positioned all over the place. Assuming that someone who understands aerodynamics has analysed this at some point; Is there an accepted best place that they should be positioned on the Jib and the Main and how many is considered preferable ? |
I would have thought it depends on the boat. However most boats I have sailed have 3 or four sets per sail and are near the front edge of the sail, closer on the jib than the main. Of course you could ask your sailmaker or just copy one of the top boats in your class. |
Bonnie Lass Contender 1764
I find it best to attach them to the sail.... Edited by Strawberry |
Mopps ![]() Groupie ![]() Joined: 25 Jun 07 Location: United Kingdom Online Status: Offline Posts: 87 |
i'm definately with stu on this on
very useful place to put them x |
I am the boatwhore
B14 694 |
Three on the jib is good, at ¼, ½ and ¾ height. Then you can tell if the jib has the right amount of twist - they should all break at about the same time when you luff. They should be well away from the luff and any seams so they can't get hooked on. On the main you'll definitely want one on the leach near the top batten - if its not streaming most of the time you have the top of the sail oversheeted. Have a look at some of the America's Cup Footage - they spend millions on getting them right so are probably worth copying. |
I agree, three on the jib at ¼, ½ and ¾. Should be easy to find some pics online that show how far back from the jib luff/forestay. You also want a jib leech telltale at about spreader height.
For the main you want 3 (or more for a big main) on the leech, all > 6" from the battern pockets (they mess up the flow). Then in line with each leech telltale, put one 1/3 to half way back from the mast (distance is prob class dependant). Any closer and you risk putting it in the separation bubble behind the mast which is a pointless location for a telltale! It also goes without saying that the leech telltales need to be spinnaker material. Look here for info on reading them http://www.onemetre.net/Race/Telltale/Telltale.htm Most new sails come with telltales attached so find someone in you class with nice new sails and copy the positions. Edited by m_liddell |
Thanks for that very useful indeed. That link to interpreting what they mean is also good info as well.
I usually have three in a row in the lowest position on the jib. These are the ones I use for pointing angle, and having three gives me finer control. It takes some time though before you know which one to sail to in which conditions! The higher ones can be single, because all you need them for is to monitor sheeting/slot.
Speed Sails ![]() Newbie ![]() Joined: 18 Jan 06 Location: Great Britain Online Status: Offline Posts: 6 |
As a rough guide, tell tales on the jib should be attached approximately 7 inches back from the luff of the sail.
On a boat with no jib around 6 mast diameters works well.
Page 123> |
