New Posts New Posts RSS Feed: Stot strip & glue
Stot strip & glue
tornado435 View Drop Down
Post Options Post Options   Quote tornado435 Quote  Post ReplyReply Direct Link To This Post Topic: Stot strip & glue
    Posted: 25 Oct 06 at 9:23am
Slot gasket material from the local chandlery. Evo stik from B&Q, make sure it is the full strength evil melt your nostril type though.
On the tornado we actually cut out the shape of the centreboard in the down position, as we are lazy and leave it down all the way around the course.
I find it is better to have two halves rather than just slitting it down the centre.
Make sure you key the boat and the gasket material well with sandpaper and clean with acetone. Mask off the area you want to attach glue to on the hull and the gasket. Do not go to the edge of the hull as you need to allow the gasket to move slightly, as the board goes up and down.  Apply glue to both sides, allow to go touch dry, then very carefully apply to hull after removing masking tape
For extra security we add a strip of the brown parcel tape to the leading edge, mostly because the trolley can rub on this when on shore.
Job jobbed
get a beer.
rogerd View Drop Down
Post Options Post Options   Quote rogerd Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 06 at 8:57am
I used evo stick on my old planker Hornet three years ago with some gasket I bought from one of the online chandlers. The salt hasnt dissolved it and its still there.
tgruitt View Drop Down
Post Options Post Options   Quote tgruitt Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 06 at 8:40pm
this isnt for inside the centreboard case! Its for the slot gasket on the bottom, the bit that stops the water going up!!
49erGBR735HSC View Drop Down
Post Options Post Options   Quote 49erGBR735HSC Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 06 at 8:14pm
Rick,
Have you tried Holt Jap tape? We're using it for our rudder gasket and I'm starting to prefer it to webbing, carpet and that horrible fluffy white stuff you get from some chandlers. Jap tape doesn't hold mosture, grit or salt particles. It's got sticky stuff on the back of it so advise at this time of year heating it whilst applying with a hair dryer to get the glue to bond better.
Dennis Watson 49er GBR735
Helensburgh S.C
Lukepiewalker View Drop Down
Post Options Post Options   Quote Lukepiewalker Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 06 at 6:56pm
Surely the only approach to such things for a National 12 sailor is to phone P&B and ask Tom.....
Works for most things....
Post Options Post Options   Quote tgruitt Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 06 at 6:29pm
oh I didn't know that! there is some contact adhesive from Wickes, that seems to stick well!
Guest View Drop Down
Post Options Post Options   Quote Guest Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 06 at 6:01pm
My understanding as that salt water attacked evo stick making it fall off
Post Options Post Options   Quote tgruitt Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 06 at 11:53am
the only thing is 12's dont have that metal bit on there. I agree with the contact adhesive and packing tape, always worked when i sailed one.
Iain C View Drop Down
Post Options Post Options   Quote Iain C Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 06 at 9:23am
RS700 GBR922 "Wirespeed"
Enterprise GBR21970
Bavaria 32 GBR4755L "Adastra"
Post Options Post Options   Quote rogerd Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 06 at 8:24am
There is a long thread on the fireball forum about slot gaskets. Everyone seems to use evo stick but get it from a builders merchants not from B&Q type stores as they use a solvent free type which doesnt work.
