New Posts New Posts RSS Feed: Plastic Dinghy Trolleys
Fundoctor View Drop Down
Post Options Post Options   Quote Fundoctor Quote  Post ReplyReply Direct Link To This Post Topic: Plastic Dinghy Trolleys
    Posted: 04 Oct 06 at 5:30pm
Someone at my club has a trolley for their laser made of plastic piping. Works a treat and weighs about 3Kg instead of 24Kg. Before I try and construct my own has anyone any idea where plastic trolleys can be bought or even have one to sell. It is the bit that the boat rests on that I really need.
rich96 View Drop Down
Post Options Post Options   Quote rich96 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 06 at 5:49pm
The original Laser plastic trolleys were indeed light - but awful in every other way !
They were so low that you always seemed to scrape the bottom of the transom on the ground.The main support dug into the sand and, as you needed to keep the bow near the floor to stop the transom scraping, you did your back in wheeling it around.
Otherwise they were great !
I'm sure that they have stopped procuction and hopefully burnt the plans !
Guest View Drop Down
Post Options Post Options   Quote Guest Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 06 at 5:53pm
Not as bad as the origional Topper trollies ...
Worthy View Drop Down
Post Options Post Options   Quote Worthy Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 06 at 6:12pm
When I was a lad we got the plastic from a plumbing shop when making trollies for Oppies
Ian99 View Drop Down
Post Options Post Options   Quote Ian99 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 06 at 7:08pm
To make the cradle for the boat, the easiest way is to use the boat as a mould and build it out of fibreglass.
Cover the boat with a load of parcel tape in the area you're using as the mould, put some epoxy on top of the tape with a paintbrush, lay on some glass, paint on some more epoxy, then more glass and carry on until you've got 3 or 4 layers of glass. Once the whole lot's cured, by peeling off the parcel tape you should be able to separate your newly made cradle from the boat, glass on a few bits of wood where you need to attach support points and attach it to your trolley frame. Glue some cheap doormats (the rubber ribbed variety) onto the boat side of the cradle and as if by magic you have a trolley!
For the frame, if you want a light trolley, try to find some broken masts/booms and use those - much better than plastic.
One warning though - don't use too much epoxy, and make sure that you've completely covered the area where the epoxy goes in parcel tape, otherwise you might end up with a load of glass cloth stuck to the underside of your boat and no easy means of getting it off
Xpletive View Drop Down
Post Options Post Options   Quote Xpletive Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 06 at 8:23pm
The plastic Laser trolley was made for them by MoveVirgo Ltd www.movevirgo.co.uk. Although the website doesn't mention it, they can still supply bits, particularly the tubing. I found them very helpful when I dealt with them a couple of years ago. (Throughout 18yrs of Laser sailing, I've found the plastic trolley is far easier to use than a metal one)
Post Options Post Options   Quote Fundoctor Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 06 at 9:09pm
Ian99 and Xpletive - thanks for those leads. Which do you think would be easier on back of back-disabled dinghy person - plastic trolley or metal one with high handles at front and jockey wheel?
redback View Drop Down
Post Options Post Options   Quote redback Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 06 at 10:50pm
Those plastic trolleys were great for car topping a Laser.  Light meant it was possible to singlehanded put it on top of the boat on a roof rack.  Being low you could launch the boat in very shallow water which is a great help when single handed because it means the shore is not so far away which is quite important when you want to leave the trolley on dry land whilst you have the boat on the wet.
I may have an old if battered cradle round the back of the shed.  It's yours if you care to collect it - I live near Tunbridge Wells.  Let me check first.
Philsy View Drop Down
Post Options Post Options   Quote Philsy Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 06 at 8:37am
When I was young I made a Minisail trolley out of plastic drain pipe and a
pair of standard dinghy trolley wheels. The cradle was wood with
polystyrene sections to give it shape - worked superbly.
Phil
Edited by Philsy
Post Options Post Options   Quote Fundoctor Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 06 at 8:50am
Redback - TW a bit too much of a trek from Bristol but thanks for the offer++ :-)  I am interested in the challenge of making my own out of FG
