Can you help me? |
Europe GBR351 ![]() Newbie ![]() ![]() Joined: 26 Apr 06 Location: United Kingdom Online Status: Offline Posts: 5 |
![]() ![]() ![]() ![]() Posted: 26 Apr 06 at 1:34pm |
Hi, At the moment I am writting an essay for my uni course. The subject of which it covers is manufacture, materials and design. The basis of it is comparing composites, GRP, FRP, kevlar and carbon fibre to wood. And I'm using the subject sailign dingys as an example. There a few questions that I'm finding really diffucult to find and also I'm including personal preference for which material do people prefere if they had a choice considering looks, performance, maintenance etc. Does any one know when the first GRP boat was produced?I found the Soling produced the first 5 GRP boats in 1966 but I dont know whether that was first 5 GRP Solings (I know they didnt produce wooden ones) or whether that was first for all sailing dinghys. It would be useful to also have price differences in one class about having an identical boat in wood and GRP (something like a Enterprise or Graduate or similar) to compare prices. I'm finding it really diffucult to find prices online (I should probually contact companies and ask but Im a student and therefore lazy And personal preference. If you could help I would be really grateful. When I use any info off here I will reference it back to this page and reference from you, so when you post you are giving me permission to use it (thats all that out of the way!!). Many thanks Claire |
BigFatStan ![]() Groupie ![]() Joined: 31 Jan 06 Online Status: Offline Posts: 78 |
Didn't take me 5 minutes to find reference to dinghies built in GRP around 1950 - do some work ya lazy student type.
Put a post on cvrda.org there is a wealth of dinghy history on there. Or wait for Rupert to post you a reply. |
Boatboy ![]() Newbie ![]() ![]() Joined: 27 Mar 04 Location: United Kingdom Online Status: Offline Posts: 15 |
the first real reference i can find to a boat built in grp is 1954 on scott baders website scottbader.com thats a big boat though 16.8m, but i believe the first boats where being produced in the late forties. in terms of cost it depends entirerly on materials used a fully finished mahogany boat will cost more than a ply boat in the same way a boat built out of choppy will cost a lot less than a nomex cored carbon skinned vessel and your best bet is to ring around and ask. you might need to be quite specific about the type of wooden boat you are looking at aswell as the type of frp boat just as a material cost guide on the frp side glass currently costs about £3 per sq metre (200gsm) and carbon in the region of £20-£30 per sq metre (200gsm) not that many purely aramid boats around still unfortunatly it doesn't like compression can't actually think of anyone building purely in aramid at the present time maybe someone can correct me personal preference i would build my next boat out of pre-preg carbon with a nomex and foam core if i had the money to do it, but it will probely end up as vac bagged carbon with a foam core. this is mainly on performance as its painted anyway so that takes care of looks its also so easy to maintain, repair and modify as well. bb |
i always thought that the first glass and carbon boats were the 14s and the 18s
TWO FRANK-Hunter Impala
This is great thanks. I found that info about the on the Scott Bader website thanks. I also found out that GRP was first introduced in the Second World War with it being put onto planes to replace some plywood, and then it was applied to boats after that. I will have a look at the history of the 14's and 18's cheers. If I had a choice my Europe would be built out of carbon (to make it even lighter Many Thanks Claire |
What course are you doing. i have just done an allnighter on marine stability of a whitbread 60. shame i went out first and got a bit peeved. it isnt too bad for a drunken attempt |
Here's a refence to a very early fibreglass boat builder in the UK.
http://www.woodenboatassociation.com/TOD%20Boats.htm The next thing you need the look at is when cored construction came in as opposed to solid. I believe that was in the US in the late 60s but don't know. On the skiff side there's a paragraph on the bottom of this page on early cored boats in NZ/AUS http://www.sailingsource.com/cherub/des60.htm And there's an article on one of the very first cored homebuilt boats in the UK http://www.sailingsource.com/cherub/dsteele.htm But I've heard that Hobie Cats or something of the like were factory mass producing cored catamarans long before that date. I seem to remember that one of the early long distance catamarans was foam core too. |
In Britain at least, the Kestrel, in the late 1950's, was one of the 1st sucessful boats designed for building in GRP, but I'm sure many boats had been adapted before that. Many early glass boats had flaws due to a lack of knowledge of the building materials, and were both weak and heavy. Finding info on these would require much research, so therefore I don't suppose it will happen... If I dare mention Dinghy Sailing Mag here, they are running a series of articles on lost classes which may well cross over into this territory. Just dug out my 1958 dinghy year book, and there is an article in it about plastic construction of dinghies by John Westall (505 designer). He is explaining the concept, which suggests that pre 1957, it was rare indeed, and he discusses foam sandwich as a theoretical concept. |
If it helps any, the Wineglass was also designed in 1958/9 specifically for GRP construction, but I guess the 505's may have been fibreglass by then too. I have a 1943 book about dinghy design written by an I14 sailor (so leading edge) which doesn't mention GRP at all, so my guess is sometime between 1944 and 1958.
