Mark Rounding |
redders ![]() Groupie ![]() Joined: 30 Dec 04 Location: United Kingdom Online Status: Offline Posts: 41 |
![]() ![]() ![]() ![]() Posted: 22 Dec 05 at 1:34pm |
Scenario: 75 minute pursuit race on reservoir...Start line is a mark of the course as port end of line and a laid mark as starboard......Mirror approaching mark to round to port at the end of her first lap....Tasar on port about to start approaching the mark. Question: Can the Mirror claim inside boat with overlap or can the Tasar shut the door as she is about to start? |
I am having trouble understanding your description. "Start line is a mark of the course as port end of line and a laid mark as starboard" makes no sense to me.
If they were on the same lap the Mirror would have water. If they were both starting then the Taser would have right of way. In this case I don't know ... daft race officer - should have made the course bigger to make sure they got all classes off before the first starter lapped. Rick |
Makes sense to me but im not sure of the answer Im pretty sure redders means that one end of the start line is also a mark of the course. Boat A is rounding that mark when racing. Boat B is cutting close to that mark in a starting situation, who has rights? Edited by Isis |
Yes I gathered that much as well but I can't visualise the situation precisely from the description. |
Lets look at the rules. By askling for water Mirror wants rule 18 to apply. Does it?
OK, well 18.1a says when the boatS plural are approaching to start. Mirror is not approaching to start so I would say that rule 18 applies and therefore Mirror is entitled to room. |
Possibly, but I was wondering whether 18.1b applied. Mirror is described as being about to round a mark to port, so presumably is on starboard, while the Tasar is on port. However the description isn't clear enough to be sure. That's why I asked for clarification but the OP seems to have gone away.
Redders needs to clarify the rounding. Is the mirror rounding in the opp. direction to the starting direction or not. I.e. if boats are both on Stbd (tasar starting) and mirror rounding the mark (AKA CTTE boat maybe) then I think that JimC is correct and the Tasar (or tasars) must give room to the mirror as per his reasoning. The windward most Tazar must give the mirror room as the mark is a mark of the course. If the boats are on opp tacks then it's Ports vs STBD w vs L - end of story
Now could get VERY interesting if another (Late)Taser spots what is going to happen and tried to follow the Mirror around and then tack away. |
john.d.knight ![]() Groupie ![]() ![]() Joined: 09 Jul 04 Location: United Kingdom Online Status: Offline Posts: 42 |
I would agree with Jim C regarding the mirror being allowed to call water, but would the Taser be allowed to call for water for the mirror if there are other boats to leeward. The Taser would nolonger asking for water on the start mark, not allowed under 18.1(a), but now needs water to pass an obstruction, the mirror.
Edited by john.d.knight |
Pain is just weakness leaving the body.
Yes the Tasar can call for the water IMO (might be difficult to get mind if the rest of the boats are racked up tight). Simple solution is to not set the course like this and put the last mark before going thru the line a little to leaward of the starting line (as we do at Grafham).
