Fairing a polyester hull |
ChrisB14 ![]() Posting king ![]() Joined: 29 Oct 13 Location: London Online Status: Offline Posts: 101 |
![]() ![]() ![]() ![]() Posted: 01 Oct 15 at 5:16pm |
Our not-so-young B14 has a few shallow dents in the bottom hull that we would like to repair/fair.
As the boat is polyester resin based, it would probably make sense to use polyester (and light, fairing filler) for this job. Having only worked with epoxy so far, I am a bit uncertain which polyester resin to go for and what I need to look out for. I have searched the web a bit and found some basic information, but as with epoxy, I suspect people have their preferred brands and variants. Also, I am assuming I can use the same fillers I would use with epoxy. As always, any advice or pointers are more than welcome!
B14 GBR 748 Bullet B
In build: Farr 3.7 GBR 410 (both sail number and the current number of loose parts) |
I would definitely use epoxy. It will stick much better and shrink less. Ther are no issues with compatability with a cured polyester laminate.
This depends on what you plan to do afterwards. If you paint the hull it doesn't really matter too much what you fill the dents with.
If you are planning to do gelcoat repairs then i wouldn't use epoxy as unless conditions are ideal you will have trouble getting the gelcoat to stick properly. The two systems are inherently incompatible and unless the epoxy is super well cured and was mixed at 100% the correct ratio you will have problems. Cooking the repair sorts most problems out, but may cause other issues on a polyester hull. Personally i'd use polyester on a polyester boat. But i'd use good quality resin, glass bubbles and silica to attain the desired consistancy. Polyester stopper or car filler is not the way forward. Polyester systems get a bad press, but if it's what the boat is built out of theres not a great deal of point in using anything better. Just use good quality products from a composites supplier, not P38 or David's Fastglass.
Edited by Paramedic - 01 Oct 15 at 6:48pm |
Thanks for the helpful replies! Paramedic: any particular brand or make of polyester that you would recommend?
Are you planning simply to fill over the top of the gelcoat? If so, I'd say that more important than the type of resin is the preparation of the surface. Nothing really likes sticking to gelcoat.
I am planning to grind into the dent with 60 or 80 grit paper. If I can get away without grinding into the foam, I am happy. I wasn't aware that gelcoat was such a bad surface to bind to.
Grit that coarse should give a good enough key. Gelcoat tends to be slightly waxy, and stuff can simply peel off, especially if you have a feather edge.
Chris,
You don't want to be anywhere near the foam when you are preparing the surface. If you have done that you have a real problem. You need to only key the surface, and a good filler will stick to this. If you start to see the first fibres of the surface plies stop. Your hull will have a series of hollows where the hull shell lamiante has shrunk onto the support structure. You can either fill the hollows or try to remove the bumps to get a fair hull. You want to do the former not the latter. Using a straight edge and an old sail batten find the hollows, mark them and see how low they are. This tells you where and how much filler to apply. You will need a few goes on the filler to get it fair. ( using a fairing board not a power sander) Working hard at this stage will make the final stage easier. A high build epoxy primer is then applied faired back, sometimes a few coats are needed. Finally a 2K paint system. With a job like this you can miss out stages or use other materials to save time and or money but this is how it should be done IMO! |
I think we might be picturing two different jobs here, oats, one doing small dents, the other the whole hull. Either way, mind, the foam should not be on view, as you say! I had visions of filler on top of shiny gelcoat, though, which really wasn't going to work.
To me the size of the job doesnt really matter whether you are fairing up a complete hull or doing a small local refairing I'd rather use the best materials. However the reality is that for small jobs most people go for a quick polyester filler and then go straight on with top coat. Often the oroblem is that its difficult for retail customers to get small amounts of the right materials so its a trip down to halfords for the P38. Sometimes its the only practical option.
