How to safely increase weight |
Eminoxon ![]() Newbie ![]() Joined: 12 Jun 13 Location: Bicester Online Status: Offline Posts: 32 |
![]() ![]() ![]() ![]() Posted: 28 Jun 13 at 11:10pm |
Hi guys, my daughter is a really keen sailor and crews in a feva or sails a tera. Trouble is she is only 23 kg( and 8 1/2 yrs old). She struggles to right the tera ESP when it turtles! Any ideas on safely increasing weight (apart from eating more pies!) or an alternative boat? Even the oppie has recommended weight of 40kg, with tera at 30.
Newtothis
RS feva 4624, share Rs200 1317, daughters RS tera 798 rs aero 1301 |
Has the boat got righting lines? Not sure how you'd arrange them in a Tera but probably possible. If you have a thickish rope each side of the boat attached to something solid you can lean back on those to get more leverage.
yes it has got righting lines, perhaps youre right and she just needs to get a better technique...
Newtothis
Well, assuming we get a summer sometime and the water warms up there might be a need to practice...
I realise this sounds a bit unhelpful, but I reckon the best could just be to keep a good idea on her- and she'll soon be heavier and taller!
Al |
Wiclif ![]() Groupie ![]() ![]() Joined: 04 Oct 05 Location: United Kingdom Online Status: Offline Posts: 82 |
How about a bit of buoyancy (an empty milk carton?) at the masthead so a capsize doesn't become a turtle
how do you fix the milk carton onto the masthead? it is a sleeve sail and doesnt have a hole at the top as far as Im aware.. but yes you are right, they work brilliantly on the feva
Newtothis
"I realise this sounds a bit unhelpful, but I reckon the best could just be to keep a good idea on her- and she'll soon be heavier and taller!"
Alstorer, you are most probably right! she is so keen she will probably learn quickly how to sort it out, and her reactions are already fast enough to prevent most capsizes
Newtothis
Weight? Wait.
Probably isn't very safe or healthy to go trying to change her weight at this age, might not be the best thing for her in the long run. As the others have said, I'd wait it out until she's bigger or work on her technique. Technique is a pretty big part, I've watched 2 girls right a 49er before, which is a task that pairs of 80kg blokes sometimes struggle with!
