sail track |
winging it
Really should get out more Joined: 22 Mar 07 Online Status: Offline Posts: 3958 |
Topic: sail track Posted: 25 Jun 12 at 4:24pm |
the track on my carbon mast has become chipped off in one place about 3 inches long (mast fell over and hit a laser). I'm guessing I need to take the track off and glue in another section. Is there a best/better way?
dogslife
Groupie Joined: 17 Feb 12 Online Status: Offline Posts: 58 |
Post Options Quote Reply Posted: 26 Jun 12 at 12:43pm |
Being careful not to cut into the carbon mast section, cut the ends of the track back either side of the damage with a hack saw. Next cut as much of the broken track off between the saw cuts as you can and then carefully file anything that remains just down to the carbon. Cut a new piece of track to fit the gap and carefully radius/smooth all the cut edges of the sail track so that they don't damage the bolt rope tape as it slides up and down the mast. Degrease all surfaces with some acetone or similar. To stick the section of track back on, use something like Plexus MA310 <http://www.ldcsailing.com/?searchStr=plexus&x=0&y=0> which is a self mixing, two-part methacrylate adhesive, that has a working time of between 15 & 18 mins and reaches 75% of is ultimate strength in 30-35 mins at approx room temp. It's worth noting that LDC will effectively lend you the applicator gun (£37.48 - refundable) so you only have to buy the adhesive and nozzle, currently £13.78 & £0.96 respectively. Before you apply the Plexus it's worth putting masking tape about 2mm outside of the areas to be bonded (mast & sail track) as this will help produce a tidy repair as you can simply wipe any surplus adhesive away and peel the tape off whilst the Plexus is still soft. |
winging it
Post Options Quote Reply Posted: 26 Jun 12 at 1:55pm |
thanks! I knew Plexus was what I needed, but didn't know where to get it.
