New Posts New Posts RSS Feed: Carbon mast varnish
Carbon mast varnish
light View Drop Down
Post Options Post Options   Quote light Quote  Post ReplyReply Direct Link To This Post Topic: Carbon mast varnish
    Posted: 11 Jul 05 at 1:02pm
I've got a superspars mast on a RS600, the mast has significantly faded so I am considering varnishing it. This is not something I've done before (with Carbon) - does anyone have any suggestions as to what to use and where to get it from? Thanks.
owain View Drop Down
Post Options Post Options   Quote owain Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 05 at 3:25pm
i think most people just use ordinary yacht varnish after lightly sanding the mast. However i may be wrong. you can buy this from a chandlery or even a DIY store may have some.
Owain H
49er GBR055
Fireball 14291
Plymouth Uni Sailing Club & Chelmarsh Sailing Club
Scooby_simon View Drop Down
Post Options Post Options   Quote Scooby_simon Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 05 at 3:52pm
Won't you just be adding weight just where you don't want it ?
F16 GBR 553 - Hungry Monster - For sale
I also talk sport here
redback View Drop Down
Post Options Post Options   Quote redback Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 05 at 9:53pm
I'd suggest you rub the whole thing down with fine wet and dry so that it is uniformly mat finish.  It will look just as good and be lighter.
But if not surely it has to be epoxy.
Edited by redback
nathan View Drop Down
Post Options Post Options   Quote nathan Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 05 at 10:55pm
Firstly tape up the fittings you cant remove easily (gooseneck/ spreader bracket) and sail track. Then lighly sand with 400ish grit wet n dry (definatly used dry). Use 2 pack polyurethane varnish to give a hardwearing finish, and apply 2 coats whilst your at it. Definatly a job to do indoors if you can.
(Thats how I varnished my 800 mast anyway!)
Stingo View Drop Down
Post Options Post Options   Quote Stingo Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 05 at 9:20am
Remember Epoxy is degraded by UV light.  If your mast is stored indoors, you dont actually need to do anything,  but if as I suspect you keep it outside and the protective layer over the structural laminate is degrading . . . . . :-(
Several coats of varnish or a coat of paint will provide UV protection (and look good :-)  ) Any decent brand of Spar Varnish is specially formulated for flexible substrates and high UV protection
Why not talk to Superspars themselves for advice? They must have seen this problem before.and know how to keep the additional weight to a minimum.
Stingo Alb #1554
Post Options Post Options   Quote light Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 05 at 12:39pm
Thanks for the replys guys.
One other question which I doubt has an easy answer - I have non stlip stips (foam like grip) on the 600 which I want to replace. The problem is getting off the existing grip - is there any chemical or trick (possibly heat!) that can be used to get it off? trying to scrape it off is surprisingly slow work - I can't be the first person with this problem  cheers.
Post Options Post Options   Quote Phil eltringham Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 05 at 10:27pm
the chances are its pro-grip with a contact adhesive like evostik to hold it down, best way to get it off unfortunately is to scrape it, gently, seem to remember it working a little better when it was wet.  takes a while, use an old stanly knife blade , but scrape, do not try to cut the glue off.
FLAT IS FAST!
Shifts Happen
Post Options Post Options   Quote redback Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 05 at 11:21pm
Have you tried petrol?
KnightMare View Drop Down
Post Options Post Options   Quote KnightMare Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 05 at 11:25pm
Wont that damage the actual hull. hmmm, what is your hull made out of?
