New Posts New Posts RSS Feed: Auto rachet position
Owenfackrell View Drop Down
Post Options Post Options   Quote Owenfackrell Quote  Post ReplyReply Direct Link To This Post Topic: Auto rachet position
    Posted: 04 Apr 11 at 12:47pm
With a auto rachet where is the best place to put it?
I have the option of either on the boom end or on the transom or does it make little difference?
Thanks
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 11 at 12:57pm
IME Ratchets seem to be best put on the last block of the system before the sheet gets to your hand: there is less drag on the line when you want the sheet to run out that way.
Contender 541 View Drop Down
Post Options Post Options   Quote Contender 541 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 11 at 4:26pm
+1
We had this question (or something similar) a short while ago and the consensus was at the end of the run just as you come to hand
Crew on 505 8780
Post Options Post Options   Quote Owenfackrell Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 11 at 9:52pm
Thanks
That is what I thought but it's good to find that others also think that.
NickA View Drop Down
Post Options Post Options   Quote NickA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 11 at 10:32pm
Au contraire .... mine's on the transom; because that way the rope goes round 180 degrees of ratchet block giving more grip (it's only a 40mm block).
3604 ...lapse of reason
Javelin 558
alstorer View Drop Down
Post Options Post Options   Quote alstorer Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 11 at 6:59am
cunning positioning of the autos on our kite sheets means that as it gets windier and you move progressively further and further aft more and more of the circumference of the block is used. I think even the main ratchet, on the boom, does this to some extent, as in heavy weather the stik waggler does need to be a little further aft upwind.
Al
BBSCFaithfull View Drop Down
Post Options Post Options   Quote BBSCFaithfull Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 11 at 12:59pm
Put mine on the strop of the 14 and a single 40 on the boom. Never had a mainsheet better and easier to use
Greatfully Sponsored By
www.allgoodfun.com
Int 14 GBR 1503!!
