New Posts New Posts RSS Feed: mast straightening
mast straightening
winging it View Drop Down
Post Options Post Options   Quote winging it Quote  Post ReplyReply Direct Link To This Post Topic: mast straightening
    Posted: 13 Sep 10 at 9:38am
slightly bent ally mast to straighten.  Is there a best way so as I don't make it worse?
Merlinboy View Drop Down
Post Options Post Options   Quote Merlinboy Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 10 at 9:58am
Apparently you should not put the bent spar between fence posts to straighten.  I think the Super spars website has a guide to straightening a mast (if i remember correctly)
Barty View Drop Down
Post Options Post Options   Quote Barty Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 10 at 12:52pm
I straightened my miracle mast (round ally section) by placing it on the drive gravel, raking back the stone from under it so there was a 100 mm gap under the mast in the middle (but still stupport at the ends) and then rotated the mast so the bend was pointing up (highest part to the sky) and then just put the compost wheely bin on it for a few days.  That eventually straightened it out and you can mow the grass to increase the straightening power!
Post Options Post Options   Quote winging it Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 10 at 4:33pm
from Superspars:
Bent masts may be straightened providing the bend is gentle and there are no distinct signs of other damage. If there are signs of the spar extrusion having collapsed or large dents in the area of the bend or local damage adjacent to the spreader bracket, straightening may not be successful.
DO NOT lever the mast between two posts and attempt to straighten from one end as this will almost certainly result in an unreparable kink at one of the supports.
The mast may be straightened by supporting it on trestles, tyres or sandbags or something equally soft about 3m apart equally spaced either side of the point of maximum bend. Then with the help of a colleague or two, ease the mast down in the opposite direction of the bend - the mast will be "springy" and it takes a bit of effort to push the bend out.
Thanks Russ!
Post Options Post Options   Quote Barty Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 10 at 12:55pm
= wheelie bin and grass cuttings Smile
