Galvanised steel box / tube section suppl |
Post Reply | Page 12> |
Scooby_simon
Really should get out more Joined: 02 Apr 04 Location: United Kingdom Online Status: Offline Posts: 2415 |
Topic: Galvanised steel box / tube section suppl Posted: 07 Jul 10 at 11:55am |
Anyone know a decent (cheap) supplier of Galvanised steel box and tube sections - for a bit of work on my trailer. Webshop or close to Hertfordshire please.
Guests
Guest Group |
Post Options Quote Reply Posted: 07 Jul 10 at 12:13pm |
You may find it difficult to get because most items are galvanised after they are fabricated........welding (difficult with zinc around), cutting and drilling all break the zinc coating which defeats the object........maybe get some raw steel section and then get the whole trailer re galvanised. Most plating companies have very large tanks.
Edited by GK.LaserII |
simonrh
Posting king Joined: 10 Jan 10 Location: United Kingdom Online Status: Offline Posts: 186 |
Post Options Quote Reply Posted: 07 Jul 10 at 12:21pm |
If you intend welding galvanised steel it's not very good for your health,fumes are quite noxious (although I don't think your long term health suffers).
Vortex Asymmetric 1064
Dart 18 7118 Smartkat stunt sailor extraordinaire |
bawbag
Groupie Joined: 23 Feb 10 Location: Uzbekistan Online Status: Offline Posts: 42 |
Post Options Quote Reply Posted: 07 Jul 10 at 12:25pm |
Try http://www.metalsupermarkets.com/ might be one near you , they specialise in off cuts.
simonrh
Post Options Quote Reply Posted: 07 Jul 10 at 12:29pm |
You can normally only get thin sheet for making biscuit tins in "pre-plate" most material is post plated as "GK.LaserII" said.
I know a guy in Biggleswade who can do most metal bashing cheaply and he did some really nice plating for me recently so can probably sort the galvanising too (his brother is a plater etc). |
bawbag
Post Options Quote Reply Posted: 07 Jul 10 at 12:53pm |
Galvanised tube is definately available of shelf norm in 6m lengths various sizes . any good steel stockholder should keep this . I worked in shiprepairing office and regularily bought this for fabrications in the yard . never bought galv box section m but may be available , quick call metal supermarket as above for offcuts , short lengths, they also buy in fabricators off cuts so may have box section avail that someone has allready had galvanised . fumes not a prob with suitable mask.
Edited by bawbag |
Scooby_simon
Post Options Quote Reply Posted: 07 Jul 10 at 12:56pm |
Cheers chaps Not planning to weld it; drill and bolt fabrication. |
radixon
Really should get out more Joined: 27 Oct 06 Location: United Kingdom Online Status: Offline Posts: 2407 |
Post Options Quote Reply Posted: 07 Jul 10 at 1:09pm |
Drilling through it will break the galvanising though Simon, over time it will rust where you drilled it.
Merlinboy
Really should get out more Joined: 03 Jul 06 Location: United Kingdom Online Status: Offline Posts: 3169 |
Post Options Quote Reply Posted: 07 Jul 10 at 1:15pm |
You can buy the galvanising paint for areas you have drilled/cut. (Not sure you can call it galvanising paint if its a paint, but you get the idea)
Scooby_simon
Post Options Quote Reply Posted: 07 Jul 10 at 1:17pm |
That would be the plan; I think Hammerite does the job! |
